Deflection of beam formula NOT considering loads
The discussion centers on the deflection of beams and the necessity of considering loads in the deflection formula. It emphasizes that without a load, there is no deflection, leading to the conclusion that w = 0 results in v = 0. Participants inquire about the possibility of finding a direct formula for deflection without considering loads, but the consensus is that deflection inherently requires a load to occur. Methods such as the equation of the elastic curve and singularity functions are suggested for deriving beam formulas. Ultimately, the conversation reinforces that deflection cannot exist in the absence of applied loads.
bandramir.raj
The actual deflection formula:
v= wx(Lx2-x3-L3)
EI 12 24 24 24
requires me to consider load then shear, bending moment, slope and finally deflection.
Is there any way it can be found directly without considering the above?
I too would be interested to know this.
In my mind, if there is no load, then there is no deflection.
Unless its deflecting under its own weight that is?
If there is no load then w = 0 therefore v = 0, meaning there is no deflection.
if there was no load, of course there won't be any deflection, what I'm trying to say is that is there any direct formula to find deflection WITHOUT considering load?
Beam formulas can be derived through use of equation of the elastic curve, singularity functions, and the moment of area method. Read up on those methods.
Beams do not deflect without having a load on them to cause that deflection.
What do you mean when you say you want to find deflection without considering load? As stated previously, with no load, there is no deflection, but that did not seem to satisfy you. What exactly do you want?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
