Deflection of Plates: Calculating Voltage and Displacement | SOLVED
In summary, the problem involved finding the deflection angle of a particle passing through two plates with known dimensions and a known angle of deflection. The solution included calculating the acceleration, force, and electric field, but these calculations were not necessary in finding the deflection angle. The correct voltage applied to the plates was found to be 882V.
anyone1979
38
[SOLVED] Deflection of Plates
Answer choices: A) 63V B) 112V C) 520V D) 642V E) 882V
y = .5cm = 5 x 10^-3 m
x = 3cm = 3 x 10 ^-2 m
angle = 10 degrees
acceleration(a) = ((1.602 x 10^-19) (15000))/(9.11 x 10^-31) = 2.6 x 10^15 m/s^2
Force(F) = 2.6 x 10 ^15(9.11 x 10^-31) = 2.4 x 10^15 N
E = F/e = (2.4 x 10 ^-15)/(1.602 x 10^-19) = 1.5 x 10^4 N/C
velocity(v) = sqrt(2 x (2.6 x 10^15) x (.005)) = 5.1 x 10^6 m/s
y = (1/2) x ((1.602 x 10^-19)/(9.11 x 10^-31)) x ((1.5 x 10^4)/(5.1 x 10^6)^2) x (.03) = 1.5 m
displacement = y tan 10 = (1.5) x (tan 10) = .26
Voltage(V) = ?
I am lost here on how to calculate the voltage applied tp to plates.
V = E x .005 = 75...But the answer is not one of the choices
your equation for acceleration is wrong the acceleration is just qE/m the energy of the particle doesn't belong in there.
you aren't given the charge or the mass of the particle, so you just assumed it was an electron. That is OK. It might be better to use q and m in all calculations, they should
get eliminated at the end.
You should compute the velocity of the particle next. You know its kinetic energy if you know q.
The speed will give you the time between the plates, and the velocity change to get a deflection of ten degrees. For the deflection angle you just need the speed in the x
and y direction, not the displacement.
Ok this is what I have so far.
(15000)(1.602 x 10^-19) = 2.4 x 10^-15 J
KE = (1/2)(m)(v^2) = 2.4 x 10^-15 J
v = sqrt(2 x (2.4 x 10^-15))/(9.11 x 10^-31) = 7.3 x 10^7 m/s
x = 3 x 10^-2 m
d = 0.0025 m, y = .0025 m
x = vt
t = (3 x 10^-2)/(7.3 x 10^7) = 4.1 x 10^-10 sec
a = (2(0.0025))/(4.1 x 10^-10)^2 = 3 x 10^16 m/s^2
F = ma = (9.11 x 10^-31)(3 x 10^16) = 2.7 x 10^14 N
E = F/e = (2.7 x 10^14)/(1.602 x 10^-19) = 1.7 x 10^5 N/C
This voltage calculated is still not right...HELP
Voltage(V) = ?
V = E(d) = (1.7 x 10^5)(.005) = 850V
why are you doing this? you only need the change in velocity to get the deflection angle, NOT the distance that the particle moved.
I needed it to calculate the electric force and electric field.
But when I finished solving the problem, I did not need the electric force or the electric field. I got the answer by finding the displacement and then finding the voltage applied to the plates based on the deflection angle.
Another reason why I found the acceleration was because of what you stated above.
the deflection is the angle between the velocity vectors, before and after going through the condensator. you don't need the displacement for that.
After doing solving the problem, I came up with 882V.
I went over it every possible way I can think of.
Thank you for your help.
What is deflection of plates?
Deflection of plates refers to the bending or deformation of a flat surface, such as a metal or plastic plate, under the influence of external forces or loads.
How is voltage calculated in deflection of plates?
Voltage is calculated in deflection of plates using the formula V = Ed, where V is the voltage, E is the electric field strength, and d is the deflection of the plate.
What is displacement in deflection of plates?
Displacement in deflection of plates refers to the movement or change in position of a plate due to the applied forces or loads. It is typically measured in units of distance, such as millimeters or inches.
What are some factors that affect the deflection of plates?
Some factors that can affect the deflection of plates include the material and thickness of the plate, the type and magnitude of the applied forces or loads, and the boundary conditions of the plate's supports or edges.
How is the deflection of a plate calculated?
The deflection of a plate can be calculated using various methods, such as the finite element method, which involves dividing the plate into smaller elements and solving for their deflections, or the Navier's equation, which uses the plate's material properties and applied forces to determine its deflection.
