Density and simple harmonic motion
A mass of density d floats in a liquid of density d_L and, when pushed down a distance x and released, will undergo simple harmonic motion (SHM) as demonstrated using Newton's Second Law. The key to solving the problem involves analyzing the forces acting on the mass, including the buoyant force and gravitational force. The net force equation leads to the conclusion that the mass experiences a restoring force proportional to its displacement, characteristic of SHM. The angular frequency w is derived as w = SQRT(D_L * g / (D * H)). The discussion emphasizes the importance of setting up the correct equations of motion to show that the system oscillates back and forth in a predictable pattern.
vu10758
A mass of density d floats in a liquid of density d_L. The mass is then pushed down a distance x and let go. Use Newton's Second Law to demonstrate that the mass will undergo simple harmonic motion. Recall that the SHM equation is d^2x/dt^2 + w^2*x = 0. Assume there is no friction. Find w in terms of whatever variables needed.
I know that Newton's 2nd law is sum F=ma, and Torque = I*omega. I don't see how I can relate this to simple harmonic motion, which involves things moving back and forth in the same pattern. The answer key says that w=SQRT(D_l * g/(D*H)). However, I don't know what I am missing to solve this problem. I don't know where to start.
I think a free body diagram would be a good place to start. Then I would use Newton's second law. Torque, huh?
When the object is at rest, I have mg pulling down and buoyant force pushing up. They are equal in magnitude. The net torque is also zero.
When the object is pushed down I have f pushing down, mg pulling down, and buoyant force pushing up. This extra f is enough to push it down. My net torque is
T = IW
However, why would I use this? Isn't torque normally used when things are rotated?
T = F x R
What R in this case? Mg and buoyant are both pushing from the center in the free body diagram so I don't think there is an R. So f is the only force that contributes to the torque am I correct?
Torque shouldn't come into play. You've listed some forces, now put them into equations.
For the object at rest
I got
B - mg = 0
When it's pushed down
B - mg -f = -ma
Since B =mg
f = ma
I already know this though so how does it help prove that it's in simple harmonic motion with a repeating pattern?
Never mind I got it now. Thanks a lot for your help.
