Exploring the Density and Gravitational Time Dilation of Black Holes
In summary, the conversation discusses the concept of gravitational time dilation and the smallest amount of mass that could possibly create a black hole. The calculated Planck Density is mentioned, but it is acknowledged that our current theories may not accurately describe these extreme conditions. It is also noted that density is coordinate system dependent and there is no classical limit on density.
aise0603
Mass falling into a black hole will approach the center of the black hole at a given velocity. As it approaches the center of the black hole, from our reference frame, there is time dialation. In fact, at some given closeness, a unit of Planck time, in the mass's reference frame, is longer than the age of the universe.
Gravitational time dilation outside a non-rotating sphere
to = tf(1-2GM/(rc2))1/2
if to = Planck time
tf = the age of the universe
r = Planck distance
solve for M to find the smallest amount of mass that could possibly create a black hole
Ms = 1.09 X 10-8 kg
Density = Ms/Vs = 6.15718 X 1095kg/m3
Is that the most dense that anything could be in the universe?
What you have calculated is so called Planck Density:
http://en.wikipedia.org/wiki/Planck_units
It means that at such density we can't use GR or QM as is
We need to use more advanced theory which does not exist yet.
But could it be that in a given reference frame, nothing can be more dense than this? Just like nothing can travel faster than the speed of light, in a given reference frame.
In what context do you want us to answer your questions?
As Dmitry mentioned, we have good reason to expect our current theories won't match nature very well in these regimes. And we definitely don't have experimental data from these regimes either. So no "real" answer can be given right now.
But if you are just asking what classical theory like GR says, then the answer is no: there is no density limit. Density is coordinate system dependent, so we can choose a coordinate system which makes it arbitrarily large if we wish. So there is no classical limit on density.
Even ignoring the coordinate system issues, what would you consider a point particle. For example, what is the density of an electron?
Typical...
aise0603 said:
Typical...
Typical what? It was a good answer to your question.
Related to Exploring the Density and Gravitational Time Dilation of Black Holes
1. What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, not even light, can escape. This is caused by a large amount of mass being squeezed into a small space, creating a strong gravitational field.
2. How is the density of a black hole calculated?
The density of a black hole is calculated by dividing the mass of the black hole by its volume. Since black holes have no defined surface or edges, their volume is estimated by using the radius of the event horizon, which is the point of no return for anything that gets too close to the black hole.
3. What is gravitational time dilation?
Gravitational time dilation is a phenomenon where time moves slower in a region with a strong gravitational field compared to a region with a weaker gravitational field. This is predicted by Einstein's theory of relativity and has been observed around objects with high mass, such as black holes.
4. How does the density of a black hole affect gravitational time dilation?
The higher the density of a black hole, the stronger its gravitational field and the more time dilation occurs. This means that time moves slower near a black hole with a higher density compared to one with a lower density.
5. Can we directly measure the density and gravitational time dilation of black holes?
Currently, we do not have the technology to directly measure the density and gravitational time dilation of black holes. However, scientists use various indirect methods, such as studying the motion of stars and gas around black holes, to estimate these properties and further our understanding of these mysterious objects.
