I Understanding Equation (2.34) in Heald and Marion: A Step-by-Step Derivation
  • I
  • Thread starter Thread starter John Fennie
    Derivation Formula
The discussion centers on clarifying the last step of equation (2.34) in Heald and Marion, with participants suggesting that understanding the derivatives involved is key. One contributor explains the derivation of the electric potential from an infinitesimal charge and emphasizes the importance of a Taylor series expansion. Confusion arises regarding the appearance of a factor of 1/6 in the equation, prompting a request for more context from the original text. The conversation also touches on the relationship between this equation and other multipole contributions, particularly in electrostatics and magnetostatics. The overall consensus is that a deeper understanding of multipole expansions and their derivations is essential for grasping the equation's implications.
John Fennie
Would someone explain the last step in eq.(2.34) in Heald and Marion?
Much thanks ahead.
Much thanks ahead.
You've a far better chance of getting assistance if you upload the relevant page. Not everyone will have that book.
Likes John Fennie
Well, that's simply working out the derivatives. It's just a bit of algebra!
If you're asking about the second equal sign, it's just simple algebra working with derivatives.
If you're asking about the first equal sign, that may be the process of finding the quadrupole component of an electric potential of a multipole.
I do not have the book nor do I have the PDF file, so I'll just explain from scratch.
Well, let us put an infinitesimal charge dq reside on a "source point", located on the position
x = (x1,x2,x3) relative to the origin. (Vector notation in boldface)
Then we can get the exact electric potential at position r as`
φ(r) = 1/4πε0 ∫ [dq/(| r - x |)]
and the infinitesimal charge dq as
dq = ρ(x)dx1'dx2'dx3'
If we perform a Taylor series expansion on the function 1/| r - x | = 1/[(x1 - x1')2+(x2 - x2')2+(x3 - x3')2] about x = 0, the third term after using the summation convention will be the term inside the summation operator multiplied by 1/2. I don't get why suddenly there's a 1/6 in front of the operator, so if you have more parts of the book I suggest you upload it. :)
That equation looks a lot like equation (12) from @vanhees71 recent Insights article: https://www.physicsforums.com/insights/homopolar-generator-analytical-example/ I worked through the calculus of that and verified it was correct. It may not be the exact same thing, but I think it is likely the formulas leading up to it are quite similar. It's hard to tell for sure, because the OP is rather incomplete, but they do like quite similar. Also, I'm not sure what the (4) in ## \Phi^{(4)} ## represents.
It's the quadrupole contribution to the electrostatic potential (or, if you use a magnetostatic potential in regions of space, where there are no currents the magnetostatic quadrupole contribution to this potential).
In statics it's always derived from the (free) Green's function of the Laplace operator,
$$G(\vec{x},\vec{x}')=\frac{1}{4 \pi |\vec{x}-\vec{x}'|},$$
fulfilling
$$\Delta_x G(\vec{x},\vec{x}')=-\delta^{(3)}(\vec{x}-\vec{x}').$$
You can most easily get the first few multipole moments from assuming ##r=|\vec{x}|\gg r'=|\vec{x}'|## and then doing an expansion in powers of ##r/r'##. Then you get the multipole moments in Cartesian coordinates, but that method becomes quite inconvenient at higher orders, and it is more convenient to use the mutlipole expansion in spherical coordinates, i.e., the representation theory of the rotation group SO(3), leading in a very beautiful way to the spherical harmonics. That's why I believe that didactically it would be much better to teach QM 1 first and then classical electrodynamics, because then you can teach the mathematical methods needed in field theory on hand of the relatively simple Schrödinger equation rather than right away jump into Maxwell theory with it's many vector fields :-).
Likes AbnormalStudent
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
