Derivation of Heat Equation for frustum-shaped rod
The discussion focuses on deriving the heat equation for a frustum-shaped rod, assuming constant specific heat and density, with no heat source present. The user attempts to apply an integral method, noting that the cross-sectional area varies along the rod. They derive an equation involving the heat flux at the ends of the rod and an integral over the cross-sectional area. However, they express uncertainty about the correctness of their last step, which diverges from class examples. Assistance is sought to clarify the derivation process.
telercoi
Derive the Heat Equation for a rod in the shape of a frustum. Assume the specific heat c and density p are all constant. Use the "exact" method (through an integral) to derive the heat equation. Also, there is no heat source in the rod.
The cross-section area for this rod is not constant, thus A=A(x)
\frac{\mathrm{d} }{\mathrm{d} t} \int_{a}^{b} e(x,t)A(x)dx
= \Phi(a,t)A(a) - \Phi(b,t)A(b)
=-\int_{a}^{b}\frac{\mathrm{d} }{\mathrm{d} x}(\Phi(x,t)A(x))dx
=-\int_{a}^{b}\frac{\mathrm{d} \Phi(x,t)A(x))}{\mathrm{d} x} + \Phi(x,t)A'(x)dx
And this is as far as I've gotten. I think the last step may be incorrect as well; it's quite different from anything we've done in class. Can anyone help please?
\frac{\mathrm{d} }{\mathrm{d} t} \int_{a}^{b} e(x,t)A(x)dx<br /> <br /> = \Phi(a,t)A(a) - \Phi(b,t)A(b)<br /> <br /> =-\int_{a}^{b}\frac{\mathrm{d} }{\mathrm{d} x}(\Phi(x,t)A(x))dx<br /> <br /> =-\int_{a}^{b}\frac{\mathrm{d} \Phi(x,t)A(x))}{\mathrm{d} x} + \Phi(x,t)A&#039;(x)dx
Put tex tags around your equation.:smile:
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
