Derivation of the velocity of an expectation value
mtmn
I am trying to derive for myself the velocity of the expectation value from the information given, specifically that
<x> = \int_{-\infty}^{\infty}x|\Psi (x,t)|^2 dt (1)
Eq (1) can be transformed into,
\frac{d<x>}{dt} = -\frac{i\hbar}{m}\int\Psi^*\frac{\partial\Psi}{\partial x}dx (2)
I couldn't come up with Eq. (2). Below is my work.
2. Homework Equations .
Schr\ddot{o}dinger Equation
i\hbar\frac{\partial\Psi}{\partial t}=-\frac{\hbar^2}{2m}\frac{\partial^2\Psi}{\partial x^2}+V\Psi
Taking the derivative of both sides of Eq. (1) results in,
\frac{d<x>}{dt} = \int x\frac{\partial}{\partial t}|\Psi|^2 dx (3)
As \Psi^2 = \Psi^*\Psi taking the derivative of the r.h.s of Eq.(3) results in,
\int x\left(\Psi^*\frac{\partial\Psi}{\partial t}+\Psi\frac{\partial\Psi^*}{\partial t}\right) (4)
Manipulating the Schr\ddot{o}dinger Equation to get \frac{\partial\Psi}{\partial T}
-\frac{\partial\Psi}{\partial t} = \frac{\hbar}{2im}{\partial^2\Psi}{\partial x^2}-\frac{V\Psi}{i\hbar} (5)
Multiplying both sides of Eq. (5) by i^2,
\frac{\partial\Psi}{\partial t} = \frac{i\hbar}{2m}\frac{\partial^2\Psi}{\partial x^2}-\frac{iV\Psi}{\hbar} (6)
Taking the complex conjugate of Eq. (6),
\frac{\partial\Psi^*}{\partial t} = -\frac{i\hbar}{2m}\frac{\partial^2\Psi^*}{\partial x^2}+\frac{iV\Psi^*}{\hbar}(7)
Substituting Eq. (6) & (7) into Eq. (4) results in,
=\Psi^*\frac{i\hbar}{2m}\frac{\partial^2\Psi}{\partial x^2}-V\frac{i\Psi^*\Psi}{\hbar}-\Psi\frac{i\hbar}{2m}\frac{\partial^2\Psi^*}{\partial x^2}+V\frac{i\Psi^*\Psi}{\hbar}
=\Psi^*\frac{i\hbar}{2m}\frac{\partial^2\Psi}{\partial x^2}-\Psi\frac{i\hbar}{2m}\frac{\partial^2\Psi^*}{\partial x^2}
=\frac{i\hbar}{2m}\left(\Psi^*\frac{\partial^2\Psi}{\partial x^2}-\Psi\frac{\partial^2\Psi^*}{\partial x^2}\right)(8)
Eq. (8) is equivalent to,
\frac{i\hbar}{2m}\left[\frac{\partial}{\partial x}\left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)\right](9)
(The inside can be confirmed just by taking the derivative, which I'm going to leave out for brevities sake)
So, the velocity of the expectation value now becomes,
\frac{d<x>}{dt} = \frac{i\hbar}{2m}\int x\frac{\partial}{\partial x}\left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)dx(10)
Taking the constant out I solved the integrand by using integration by parts.
Let u=x
dv=\frac{\partial}{\partial x}\left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)dx.
Then, du=dx
v=\left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)
Substituting this into \int udv = \int uv-\int vdu
x\left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)\bigg|_{\infty}^{\infty}-\int \left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)dx (11)
Before the integral that term goes to 0 because (as I'm told, I don't actually know how to prove this) \Psi goes to zero must quicker then x goes to infinity. So the velocity becomes,
\frac{d<x>}{dt} = -\frac{i\hbar}{2m}\int \left(\Psi^*\frac{\partial\Psi}{\partial x}-\Psi\frac{\partial\Psi^*}{\partial x}\right)dx(12)
I transformed,
\Psi\frac{\partial\Psi^*}{\partial x}=\frac{\partial\Psi^*\Psi}{\partial x}-\Psi^*\frac{\partial\Psi}{\partial x}(13)
Substituting Eq (13) into Eq (12),
\frac{d<x>}{dt} = -\frac{i\hbar}{2m}\int \left(\Psi^*\frac{\partial\Psi}{\partial x}-\frac{\partial\Psi^*\Psi}{\partial x}+\Psi^*\frac{\partial\Psi}{\partial x}\right)dx
=\frac{d<x>}{dt} = -\frac{i\hbar}{2m}\int \left(2\Psi^*\frac{\partial\Psi}{\partial x}-\frac{\partial\Psi^*\Psi}{\partial x}\right)dx(14)
Eq.(14) Becomes
\frac{d<x>}{dt} = -\frac{i\hbar}{m}\int \Psi^*\frac{\partial\Psi}{\partial x}dx+\frac{i\hbar}{2m}\int\frac{\partial\Psi^*\Psi}{\partial x}dx(15)
The left part of the r.h.s. of Eq.(15) is what I want but I don't know how to eliminate the right portion of it.
Anyone have any ideas??
Thanks in advance!
Matt
Eqn. (15) Looks incorrect. You should only have the first term on the rhs.
EDIT:
Of course, the second term is an integral of a derivative of |\Psi|^{2} = \Psi^{\ast} \, \Psi, so it can be integrated. But, the wavefunction disappears at infinity, so the contribution from that term is zero.
So, I can assume again that \Psi^2\Psi goes to zero as it goes to infinity? If that's the case then thanks! =)
Of course. This is a necessary (but not sufficient) condition for the probability normalization integral:
<br /> \int_{-\infty}^{\infty}{|\Psi(x, t)|^{2} \, dx} = 1<br />
to converge.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
