How Do You Derive Laplace Transforms for Delayed Functions?
discombobulated
Derive the Laplace transform of the following functions, using first principles
3d) u(t - T) \} = 0, \ t<T \ (= 1, t>T)
3e) f(t) = e^{-a(t-T)}u(t-T)
see above
I know I need to derive the transform using by integration using this:
L(f) = \int^\infty_{0} \mbox{f(t) e^{-st}} \ dt
but I don't understand the notation, is T the laplace transform of t ? Is u the unit step function? so u(s) = 1/s ?
If someone could explain this to me please?
u is a function and T is a value for t, t is the variable.
Yes u is the stepfunction. You must use two useful identities in laplace transform theory.
see above
u is *defined* in the problem. yes, it is a step function, but the step does not occur at zero. tell us: where does the step occur?
so u(s) = 1/s ?
no. u depends on T as a parameter, so too will the transform depend on T as a parameter. if T happened to be zero then you *would* be correct, but T is not (necessarily) zero.
your teacher or professor or whoever obviously wants you to evaluate the integral that defines the transform. The first one should be very easy if you know how to integrate an exponential function by itself. I.e., do you know the value of this integral
<br /> \int_a^b e^x<br />
