Design an audio power amplifier
41 replies · 7K views · last reply
PhysicoRaj
Hello,
I was dissecting an old TV when I came across a set of speakers. They're 8 ohms, though I'm not sure if they're 8w or 6w..
I decided to make my own portable speakers (mono), which could be connected by means of an aux cable to my smartphone.
I don't know what's the output voltage of my smartphone headphone jack.. So please shed some light on that..
Basically I need to design a 6W power amplifier.. I have 9v batteries (Vcc).
I did some basic calculations and found out the quiescent current can fry my bias network if I used a Class A.
So I thought of a class B, and since I don't want Trafos, I am determined on a complementary pair push pull.
What power transistor would suit my application the best? How do I design the circuit.. Can the push pull provide both voltage and current gain? Do I need any other stage before this push pull?
Is cross-over distortion a major problem?
Thanks for your time and help..
Regards
Thanks a lot.. They can make my work a lot compact. I may use this..
But if the design using push pull isn't too complicated, I would like to try my luck on making my own, or even, out of curiosity to know how to design such circuits.
So any info on the design is also welcome..
Thanks again.
Applause!
I can direct you to some pages, but please start with something simple and low power. When you have done that, I can give you some links to higher power amps.
Thanks :) I noted down some circuits. As I observed it seems that almost all the circuits had a preamplifier before the complementary pair.. Is that necessary? Because the output of a jack is low, I may be needing some gain before the power amp.. With this cleared I can get started.
What's the use of Q2 in the attachment?
  • Circuit schematic of a 4 transistor audio amplifier with Audio IN input, 5V DC supply, transistors Q1 to Q4, diodes D1 and D1N4148, and an 8 ohm speaker K1 output.
Ok Thank you.. I decided to drive a push pull using OpAmp as preamplifier (I think it does the role of Q1 and Q2)..and raise the Q point of the push pull using a preset.
Thanks for the help!
OK, but be careful - not all OpAmps are capable of driving the output transistors or handling the large amplitudes needed. Some advice and circuits:
Opamp supplies have always confused me. The LM383 needs a +Vcc and ground in place of the -Vee as in the case of LM741.
When I'm dealing with batteries, how do I connect the LM383? Can I give the battery negative to ground?
http://www.reconnsworld.com/audio_8wattamp.html
yes
many op-amps work using a split rail +V, 0V, -V
in the case of a single rail supply ( + and -) the - equals GND /negative of battery or other PSU
OK thanks.. Because in my lab we worked with the op amps in +V 0 - V and the instructor used to warn us not to interchange the 0 and - V.. So I was doubtful about the single rail system.
Is a battery different from a dual power supply? Ex, what would be the -ve of a 12v battery at, 0 or - 12v? Because testing out dual supplies, my multimeter reads 24v between the terminals. That means a battery should be of +12,0 form.. Am I right?
Many of the dual rail op-amps will happily work using a single rail supply
others are specifically designed to use with a dual rail ( split supply) only ... .the datasheet for the particular op-amp gives this info
yes ... it is a single rail supply
the negative terminal is 0V relative to the positive terminal
that's correct and you have an associated 0V terminal. so with your multimeter negative ( black) lead on the 0V term. and the red lead on the +12V term. you will see +12V on the meter
and with your multimeter negative ( black) lead on the 0V term. and the red lead on the -12V term. you will see -12V on the meter
you can make a dual rail supply from a single or 2 batteries like this ...
single battery or other single rail supply
Circuit schematic of a split-rail power supply filter: input J1 feeds two 1k resistors R1 and R2 in series, with capacitors C1 and C2 (1000uF) across the rails, outputs labelled +VE, Gnd and -VE.
2 batteries ...
Circuit schematic of a dual-rail regulated supply: +VDC feeds a positive regulator LM78xx and -VDC feeds a negative regulator LM79xx, each with a 10uF input capacitor and 100nF output capacitor, sharing a central 0V rail.
Note that in the first one, two resistors are being used to produce a voltage divider
this is for small currents only as the resistors produce current limiting
so if you had, say, a 12V battery, you could produce a +6V, 0V, -6V supply
the second dual rail supply uses 2 batteries with the addition of voltage regulator IC's to produce a stable outputcheers
Dave
Ah.. That's enough explanatory :)
And one last thing.. How do I know the output of my smartphone headphone connector? DC level, peak AC, etc? Because most LM383 circuits set a gain of 100, and I want to be able to vary that gain to drive the 8 ohms speaker at 6-8 watts.
8 Ohm speaker running at 6W means approx 10V peak output voltage. So I need to know the input so that I can play with the gain.
Svein said:
Put a potentiometer in front of the input.
yes :smile:
just like this, using the circuit you linked to...
Circuit schematic of an audio power amplifier built around an LM383 op-amp (U1), with a 10k input potentiometer, C1 10, C2 470, C3 0.2, R1 2.2 Ω, R2 2.2 Ω, R3 220 Ω, C4 2000, and output to speaker SPKR1.
Dave
But wouldn't that be just like attenuating the input and having same gain.. What if I needed more than the full input voltage, I need more gain right? So I thought knowing the output of the jack would be better.
I searched everywhere but in vain.. I can't find the 3.5mm jack specs.
Thanks..
Yes.
That is the way it is done on pretty much every amplifier ever built
so if the amp has a gain of 100, you can work out the output power relative to the input power
you ONLY get max output from the LM383 ( or whatever other amp) WHEN its input is driven fully
you cannot overdrive the input to the amp it will just produce an unlistenable distorted output and possibly damage the amp chip
the full output of the headphone jack of your phone/media player could easily have enough output to overdrive the amp chip
so that is why the volume control ( attenuator) goes on the input to the amp
what jack specs ?
the max output from your smartphone ?
that will be in the phone spec sheet
http://www.kenrockwell.com/apple/iphone-5/audio-quality.htm is an analysis of the 3.5mm audio jack output. It is probably similar to any smartphone.
The smartphone output generally has a gain control, so you can send it to a fixed gain amplifier. For example iphone docks change volume (generally) by sending commands to the iphone.
davenn said:
Yes.
OK I get it..
Exactly what I wanted! Thanks a lot!
In case of a complementary push pull, the pnp transistor requires -Vee. And the load needs a ground.
How do I power this using a single battery? Can -Vee and ground of the load be given to - ve of battery? (see image)
Image is here..
  • Circuit schematic of a buffered push-pull output stage: an op-amp with Input on its non-inverting input and its output feeding a complementary NPN and PNP transistor pair between +V and -V, with the output node driving a Load resistor to ground and fed back to the inverting input.
You have to create a virtual ground at half the battery voltage and AC couple the input and output signals.
You mean like this:
  • Circuit schematic of a split-supply power rail filter: J1 input connector feeds two 1k resistors R1 and R2 in series, with electrolytic capacitors C1 and C2, each 1000uF, across the rails to +VE, Gnd and -VE outputs.
PhysicoRaj said:
You mean like this:
yes but remember that that circuit, when I posted it, I said that using a resistor voltage divider limits the available current
you would be better off using the other circuit I showed you where you use 2 batteriesDave
The other circuit features two regulators, what if I omit them.. If I have the battery of the voltage required?
yes that is OK, the reg's in that circuit were just a progression for if a well regulated supply was needed ... feeding IC's for example
