Design Factor with known reliability
  • Thread starter Thread starter James Brady
    Design
The discussion centers on the design factor equation, which is perceived as independent of geometry, leading to confusion about its implications. The equation calculates the design factor based on reliability, standard deviations, and means of material strength and load, but does not explicitly incorporate geometric factors. Participants clarify that while the equation focuses on reliability, real-world scenarios suggest that geometry influences the design factor through variations in loading and material strength. Ultimately, the design factor is not truly independent of geometry; rather, it is derived from reliability and can inform geometric considerations once established. Understanding this relationship enhances clarity on how design factors relate to different geometries in practical applications.
James Brady
In my textbook we are given the equation for design factor as:
## n_d = \frac{1+\sqrt{1-(1-z^2c_s^2)(1-z^2c_\sigma^2)}}{(1-z^2c_s^2)} ##
where
z = the z score, this is determined from reliability which is given in the problem. A high z-score means we demand a very high reliability.
##c_s = \frac{\sigma_S}{\mu_S}## that is the standard deviation over the mean of the material strength.
##c_\Sigma = \frac{\sigma_\Sigma}{\mu_\Sigma}##
Note: I'm using capital sigma for stress and lower case sigma for standard deviation to hopefully help with confusion.
So my problem with this idea is that design factor is independent of the geometry we are working with. For example, if we have a cylinder that is under a tension load and we know the mean and standard deviations of the load, we can use that to calculate coefficient of stress ##c_\Sigma## by dividing by area: ##c_\Sigma = \frac{\sigma_F/area}{\mu_f/area}## areas cancel out and we are left with the coefficient of stress.
So since area cancels out, it looks like geometry is not even a factor in determining the design factor, and I know intuitively that this cannot be true. That's essentially saying that a cylinder the size of a tooth pick will have the same design factor as a cylinder the size as my arm. And from the equation above, they will both have the same reliability.
Seriously would appreciate any help here. My professor says it's independent of geometry but I can't see how that's true. If you need any further elaboration or anything, just let me know and I'll post them up.
What is a design factor, exactly?
It looks to me a lot like a safety factor, just accounting for statistical variations in your material and load. Am I on the right track?
They are very similar concepts. From what I understand ##n_d = \frac{what- the- part- can -handle}{what- the -part- experiences}## the main difference between the two is that design factor includes all modes of failure (buckling, vibrations, etc...). So I don't think the differences is statistics, in this example we're just trying to use statistics to get a more accurate idea of when our part could fail. ^Not 100% confident on my definition there, but yeah, I know they are very similar concepts.
Ok, with that semi-settled:
All other things being equal, they would only have the same design factor if they have the same reliability.
You're not getting reliability from the equation. You're getting it from the problem statement.
In a real world scenario(within a certain range of loading), arm cylinder is likely to have a higher reliability than toothpick cylinder and, therefore, a different design factor.
Likes James Brady
Oh wow, I see that now. Reliability along with loading and strength information is given in the problem statement, and those determine the design factor. From the design factor, a certain geometry can be determined.
So it's not that design factor is independent of geometry, it's that this equation expresses it solely as a function of reliability. Once a value of n_d is found, so can everything else. I appreciate the help, knowing that made my day a little better.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
