Designing a Transfer Function in MATLAB for Servo Motor Control
This discussion focuses on designing a transfer function for servo motor control using MATLAB, specifically employing the Polynomial Equations Approach. The Sylvester Matrix E is utilized to create a controller represented by M, with the plant transfer function defined as B(z)/A(z) = D. The user seeks assistance in troubleshooting their MATLAB code, which involves unique polynomials a(z) and b(z) to achieve the desired state. The plant transfer function is confirmed to be controllable, although relevant code lines were omitted from the discussion.
  • Understanding of transfer functions in control systems
  • Familiarity with MATLAB programming
  • Knowledge of Sylvester Matrix and its applications
  • Basic concepts of polynomial equations in control theory
  • Research MATLAB's Control System Toolbox for advanced control design
  • Learn about the implementation of the Sylvester Matrix in MATLAB
  • Study the Diophantine equation in the context of control systems
  • Explore debugging techniques for MATLAB code related to control algorithms
Electrical engineers, control system designers, and MATLAB users involved in servo motor control and transfer function design will benefit from this discussion.
Ethers0n
This post is cross listed at the below url
https://www.physicsforums.com/showthread.php?t=73985
I'm attempting to use MATLAB to solve an electrical engineering problem dealing with controls...
I'm trying to design a transfer function which will control a servo motor using what is often referred to as the Polynomial Equations Aproach.
The approach uses the Sylvester Matrix E to produce a controller for a transfer function.
M = desired controller
E = Sylvester Matrix
D = Diophantine Value = a(z)A(z) + b(z)B(z)
where
PLant Transfer function = B(z)
A(z)
a(z) and b(z) are unique polynomials which you multiply A(z) and B(z) by to get your desired state...
To keep from getting everything congested, I'll not post the code here. It is at the link above. (is there a better way to display the code next time?)
Basically, I've been over the MATLAB code so many times my eyes are bleeding and I still can't figure it out...if anyone could I take a look, I'd appreciate it...
The plant transfer functin is controllable, but I didn't include those lines in the MATLAB code.
Thank you.
sorry, that's suppossed to be
B(z)/A(z) = D
darn formatting...
9K
