Designing basic circuits to power devices
alexk307
Device requires a terminal voltage of 12 volts and a current of 2 Amps. Design a circuit using as many 3 ohm resistors as needed to properly power this device. The EMF is 24 Volts.
Ohm's law: V=IR
I know how to find equivalent resistance, but I don't know how to dissipate some of the voltage, in this case, get the voltage from 24 down to 12.
Calculate the resistance of the device from the fact that V=12V and I=2A.
If the pd across it is to be 12V but the supply is 24V, then you need a circuit in which there is 12V combined across the available 3 ohm resistors and 12V across the device.
Does that help? Try both a series and parallel circuit to see which will do the job.
