Desoldering F-connector for Battery Pack
The discussion revolves around the signal loss experienced after de-soldering an F-connector from a circuit board and connecting a battery. The user connected the V+ to the center wire and ground to one of the braid connections, leaving the second ground open, which led to a decrease in signal sensitivity. It was suggested that the open ground may have disrupted the RF ground plane or impedance matching, crucial for maintaining signal integrity. When both grounds were connected, the signal improved significantly, indicating the importance of grounding in the circuit design. The conversation highlights the complexities of RF connections and the potential impact of grounding on signal performance.
mishima
Recently I de-soldered an f-connector (coax) from a pre-made circuit board. This consisted of 3 soldering connections, 1 for the center wire and 2 for the braid which was electrically connected through a mounting plate. Then I attached the V+ from a 18V battery to the where the center wire was, and ground to just one of the braid connections. My circuit seems to have experienced some signal loss as a result, and I am at a loss to explain why connecting the 2nd ground would affect anything. As far as I can tell, there is nothing on the circuit board even connected to the ground I left open. Any ideas?
Before this, the battery was connected to a normal coax cable I had stripped, V+ to the center wire and ground to the braid. I'm thinking perhaps coax has some transmission properties that aren't matched by the now present 22 AWG stranded wire. Is that the case?
The signal is in the 950-1450 range. I can provide pics if needed.
Yes, pictures would help. Are you saying that you switched from coax to twisted pair? If so, what are the Zo values of the two different transmission line cables?
I went from this (not my pic, but similar):
to this (my pic):
On the other side of the RF choke is about 4 inches of 22 AWG going straight to the positive of my battery (the other going to ground, not twisted). I don't know the Z0 values. This is for a radio telescope. My signal for this new setup isn't noisy, it just seems less sensitive when I wave my hand around the dish. I guess it could be anything really, I was just never sure about leaving that second ground open.
Without a proper RF connector and grounding for your DC power inserter it's no wonder your signal power is down. The F connector provided a ground path across the void of the PC board. I have seen 'cheap' designs that use the connector shell as a DC and/or RF signal path. If you look at your picture the two solder pads on either side of the center pad were once connected by the RF connector. Try soldering a short braid or thin sheet of tinned copper between them (spaced away from the center pad) to see if the signal level increases.
I just tried connecting the 2 grounds with some alligator clips and you are right, things are back to normal. I really have no idea why it matters though, the ground I left open isn't connected to anything on the circuit board, its just a pad with a ball of old solder on it.
I am measuring the signal with an arduino. With only 1 ground connected I would get a change in signal of about 20, with 2 grounds I get a change in signal of about 50. Can you help me understand why the second ground is necessary?
Without knowing the complete design of the circuit I can only guess but it's likely some sort of RF ground plane or impendace matching stub.
http://www.maximintegrated.com/app-notes/index.mvp/id/5100
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
20K
