Detecting Minerals through chemistry
  • Thread starter Thread starter Tetraspace
    Chemistry Minerals
To detect minerals in rocks, particularly magnesium in Hawaiian lava flows, soaking rocks in water can reveal color changes indicative of specific minerals. It is important to handle lava carefully due to its high temperatures. The discussion highlights that iron is abundant in lava, making it a common mineral to consider. For effective testing, grinding the rocks into a powder is recommended, as this increases the surface area for reactions. Additionally, exploring the effects of sodium hydroxide (NaOH) and sodium carbonate (Na2CO3) on magnesium ions can provide valuable insights. Access to a lab and chemicals is also essential for conducting experiments.
Tetraspace
What is a way to detect minerals through rocks? For example soaking water in some rocks cause the rock to change a certain color to indicate that it has a certain mineral. I'm doing magnesium in lava flows in the island of Hawaii. Yes I live in Hawaii. If you could give me some ideas that would be good. Thanks :biggrin:
Chemistry news on Phys.org
First man, don't mess with lava too much, it is hot :smile:
Well, since we don't have such experience in our hometown, it is new for me, but don't forget that iron is very plentiful in lava, so any mineral is very likely to be of iron.
Well we're only testing hardned lava rocks and some crystallization of sulfur. Secondly someone already took the iron project.
1. What grade are you in, and do you have access to chemicals in your lab ?
2. Grinding little bits of the rock into a powder helps a lot.
3. Find out the effect of sodium hydroxide (NaOH) and sodium carbonate (Na2CO3) on magnesium (Mg 2+) ions. Google might help.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
