Determine pressure of a gass in a piston-cylinder device
  • Thread starter Thread starter v_pino
    Device Pressure
To determine the pressure of a gas in a piston-cylinder device, the total force on the piston is calculated by combining the weight of the piston and the force from the spring. The area of the piston must be converted from cm² to m² for accurate calculations. The correct formula for pressure is applied, resulting in a pressure of 123400 Pa. An error in unit conversion led to an incorrect initial calculation of 95284 Pa. Properly converting the area to m² resolves the discrepancy and yields the correct pressure value.
v_pino
A gas contained in a vertical frictionless piston-cylinder device. The piston has a mass of 4kg and a cross-sectional area of 35 cm^2. A compressed spring above the piston exerts a force of 60N on the piston. If the atmospheric pressure is 95kPa, determine the pressure inside the cylinder.
Ans: 123400 Pa
P = F/A
P (at depth h) = density * g * h + atmospheric pressure
Total force = (4g+60)
P (at depth h) = ((4g+60) / (0.35)) + (95000)
= 95284 Pa (which is not what the answer gives.)
many thanks
One error, you haven't changed 35 cm^2 to m^2 properly. Try using 35x10^-4 m^2 and you get the right answer. A pretty good trick to do it if you can't remember how many "steps" you move the ,/. sign is
cm^2 = cm x cm = (1/100)m x (1/100)m = (1/100)^2 m^2 = 10^-4 m^2
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
