Determine the convergence or divergence of the sequence
zak1989
Determine the convergence or divergence of the sequence with the given nth term. If the sequence converges find its limit.
an = (1*3*5*...*(2n-1))/(2n)n
lim n->infinity an = L
The answer in the book shows:
1/2n * 3/2n * 5/2n...(2n-1)/2n less than 1/2n
So, lim n->infinity an = 0, converges
I don't understand where the 1/2n * 3/2n * 5/2n...(2n-1)/2n less than 1/2n comes from. I'm obviously missing something. Could anyone please explain that part to me? I'd really appreciate any help at all. Thanks :)
Obviously ##1 \cdot 2 \cdot 3 \dots (2n-1) \cdot (2n) < (2n)^{n}##, because in the first product all factors except the last one are smaller than in the second product.
Therefore, also ##\frac{1 \cdot 3 \cdot 5 \dots (2n-1)}{(2n)^{n}}<\frac{1 \cdot 3 \cdot 5 \dots (2n-1)}{1 \cdot 2 \cdot 3 \dots (2n-1) \cdot (2n)}=\frac{1}{2 \cdot 4 \dots (2n)}##.
Can you now tell that the sequence is convergent?
For n sufficiently large, 0 < 1/2n < 3/2n < 5/2n < ... < (2n-1)/2n < 1. So you're multiplying 1/(2n) by something which is strictly less than 1, which means that the result is strictly less than 1/(2n).
Thanks for your help, but I'm still not getting it. When I see the sequence an = (1*3*5*...*(2n-1))/(2n)^n I would think it looks something like 1/2(1)^1 * 3/2(2)^2 * 5/2(3)^3 ... Is that wrong? I don't understand where the exponent n is going from the denominator.
Yes; it's
<br /> \frac1{2n} \times \frac3{2n} \times \cdots \times \frac{2n-1}{2n} = \frac{1 \times 3 \times \cdots \times (2n-1)}{(2n)^n}<br />
since there are n factors and the denominator is the same for each.
Both, if you mean ##\frac 1 {2n}##, ##\frac 3 {2n}##, and so on, you need parentheses around each denominator. Otherwise what both of you wrote would be interpreted as (1/2) * n, (3/2) * n, etc.
Ok now I understand why those two equations are equal, thanks. It seems so obvious now. What I still don't understand is how does saying 1/2n * 3/2n * 5/2n...(2n-1)/2n less than 1/2n help me conclude that the sequence diverges?
^ Actually, the sequence converges, because you can make the quotient arbitrarily close to zero by choosing sufficiently large n.
If \epsilon &gt; 0, does there exist a positive integer N such that 1/(2N) &lt; \epsilon?
What does that tell you about the convergence or divergence of the sequence?
Oh ok so the limit as n goes to infinity is zero which means it converges, but I'm a little lost. How do I know the limit is zero? Thanks for all your help I really appreciate it :)
