Determine the moment about a given point
  • Thread starter Thread starter wannawin
    Moment Point
This discussion focuses on calculating moments about points A, B, and D using the equation Mx = F * d. The participant correctly identifies that the leftmost force at point A produces no moment. They emphasize the importance of breaking down the 52 kN force into its vertical and horizontal components to determine the moments accurately. The discussion highlights the necessity of calculating the perpendicular distances from the line of action of the forces to the points of interest, particularly for the 93 kN force and the components of the 52 kN force.
  • Understanding of static equilibrium and moments
  • Familiarity with vector decomposition of forces
  • Knowledge of trigonometric functions for angle calculations
  • Proficiency in applying the moment equation Mx = F * d
  • Study vector decomposition techniques for forces in mechanics
  • Learn how to calculate moments about various points in static systems
  • Explore the application of trigonometry in engineering mechanics
  • Review examples of moment calculations in real-world engineering problems
Students in engineering mechanics, physics enthusiasts, and professionals involved in structural analysis or statics who need to understand moment calculations about specific points in a system.
wannawin
I'm trying to find the moments about points A,B and D respectively.
Mx= F * d
Correct me if I'm wrong, but on point A the leftmost force produces no moment. After that I'm a little confused about what to use for the distances of the other two forces.
Mx= F * d
That is correct.
Breakup the 52 kN force into its vertical and horizontal vector components, applied where the arrow of the 52 kN force is is touching the line. Then remember the golden rule: The moment of a force, or component of that force, is equal to the force, or component of that force, times the perpendicular distance from the line of action of the force, or component of that force, to the point about which you are summing moments.
For example, looking now at the 93 kN force, its line of action is a vertical line. The moment of that force about A is then 93*(___?__), clockwise. Now calculate the moments for each of the force components of the 52 kN force, and add them all up.
you may also need to find the angle in the triangle made after a square.
sorry rectangle
so I can use 1.8m as the vertical distance, but by the way it looks I guess I have to find out the length of x and add it to 7 in order to find the horizontal distance.
For 52 sin 28 its 1.8 m and for 52 cos 28 you have to find the angle to find the distance which should be added with 7 m
When I click on the picture posted in post 1, it says, "This web page has been identified as dangerous. For your own safety, please close this window now, and never return to this web site." Just wanted to warn you guys. It might be dangerous.
  • · Replies 27 ·
