Determine the power of the jet engine of an airplane
To determine the power of a jet engine, the discussion focuses on the mass flow rates of air and fuel, with air intake at 130 kg/s and fuel at 4.3 kg/s. The exit speed of the burned gases is 600 m/s, while the plane's speed is 260 m/s. The initial attempt to calculate power using the formula W = v^2(DM/DT) was deemed incorrect due to misunderstanding the application of momentum principles. The conversation emphasizes the need to apply Newton's second law correctly, particularly when mass is not constant. Ultimately, the correct approach involves analyzing the force as the rate of change of momentum.
Fisicks
The jet engine of an airplane takes in 130 kg of air per second, which is burned with 4.3 kg of fuel per second. The burned gases leave the plane at a speed of 600 m/s (relative to the plane). If the plane is traveling 260 m/s, determine the power (hp) delivered.
P=Fv
M(DV/DT)=F_ext + v_rel(DM/DT)
dv/dt=0 so F=v_rel(DM/DT)
Thus W=v^2(DM/DT)=(600^2)(4.3) but this is incorrect and I do see where I am wrong.
Hi Fisicks! :smile:
You've used mdv/dt, which obviously doesn't work if m is not constant :redface:
(and dv/dt = 0, which I don't really understand)
start again, using the full version of good ol' Newton's second law …
force = rate of change of momentum :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
