Determine the rms value for the given function
The discussion focuses on calculating the RMS value of the function v(t) = 15 + 10cos(20πt). The formula used for RMS is Vrms = √(1/T * ∫T0 v^2 dt, and the initial attempt led to an incorrect result of 24.98V. The correct approach involves recognizing the contributions of the constant and cosine terms in the integration. The accurate RMS value is determined to be 16.58V, highlighting a mistake in the integration process. Proper application of the formula yields the correct result.
Northbysouth
Determine the rms value of v(t) = 15 + 10cos(20πt)
Vrms = √(1/T*∫T0v2dt
√(10*∫0.10[15+10cos(20πt)]2dt
Unless, I'm much mistaken I should be able to plug the equation into the formula I have given above. I used the integral function on my calculator to do the calculation and I got 24.98V but the answer is supposed to be 16.58V
Any suggestions for where I'm going wrong?
Your setup is correct. You must have made a mistake in the integration with your calculator.
Vrms = √15^2+(10/√2)^2 = 16.58 V
