Determine Va-Vb and the magnitude/direction of Ea-Eb
  • Thread starter Thread starter StudentofSci
To determine Va-Vb, the potential difference can be calculated using the equation Va-Vb=-∫E dl, where E is the electric field due to the point charge. The magnitude of Ea-Eb can be found using E=kQ/r^2, considering the distances from the charge to points a and b. The direction of Ea-Eb will be influenced by the orientation of the electric field lines, which point away from the negative charge. Solving the problem symbolically is essential, as it allows for a clearer understanding of the relationships involved without needing specific numerical values. This approach ensures that the conceptual framework is solid before substituting any numbers.
StudentofSci
Point "a" is "Y" meters south of a -Q C Point Charge and point "b" is "X" meters east of the charge.
1. Determine Va-Vb
2.Determine the magnitude of Ea-Eb
3.Determine the direction of Ea-Eb
My problem with solving this question is that it is purely conceptual. If there were values given than the equation that I know would be of use and I would be able to solve it. Any help as to how to answer this problem would be greatly appreciated. Thank you for your time.
Va-Vb=-∫E dl
E=kQ/r^2
Don't really know how to start.
If you can solve the problem with numbers, you should be able to solve it without numbers. In fact, you should always solve problems symbolically, and only plug in the numbers as the very last step. Obviously, for this problem, a numerical answer is not expected.
Yes that's what I figured. I just thought I ought to be sure that solving it symbolically didn't take me down some other path. Thank you
