Determining charge from electric potential
The discussion focuses on calculating the charge q on a metal sphere and a hollow spherical shell given a potential difference of 500 V. The equation used is ΔV=q/K [(1/ra)-(1/rb)], but the initial calculation yielded an unreasonably large value for q. A participant pointed out a potential error in the placement of the constant K in the equation. The correct value of K is 1/4∏ε0, which was overlooked in the initial attempt. This correction is crucial for accurately determining the charge.
rmcgovern
A metal sphere with radius ra = 1.20 cm is supported on an insulating stand at the center of a hollow, metal, spherical shell with radius rb = 9.00 cm. Charge +q is put on the inner sphere and charge -q on the outer spherical shell. The magnitude of q is chosen to make the potential difference between the spheres 500 V, with the inner sphere at higher potential. Calculate q.
Solving for q from the eqn above I have reached q= ΔV/[(1/ra)-(1/rb)] * K. By simply plugging in the numbers given I reached a soln of q= 6.23*10^10 C. This answer seemed far too large to be right, and indeed it is not correct. Is this the proper equation to use in this situation? I double checked the math and it appears everything is right, does anyone see where I may have gone wrong? Any help is greatly appreciated.
Hi rmcgovern. Welcome to PF!
Did you put the constant K in the correct location in your equation for ΔV?
ah! I forgot that K=1/4∏ε0. a rather trivial error. thank you for your help.
