Determining Local Extrema with Lagrange
cse63146
[SOLVED] Determining Local Extrema with Lagrange
Find local extram of f(x,y,z) = 8x+4y-z with constraint g(x,y,z) = x^2 + y^2 + z^2 = 9
\nabla f(x,y,z) = \lambda g(x,y,z)
So I did the partial derivatives for F and G:
\nabla f(x,y,z) = (8,4,-1) \nabla g(x,y,z) = (2x,2y,2x)
Now I use Lagrange to get
8 =2 \lambda x , 4 = 2\lambda y , -1 =2 \lambda z
Now I isolated \lambda = \frac{4}{x} = \frac{2}{y} =- \frac{1}{2z}
Now I re-write both y and z in terms of x and I get:
y = \frac{x}{2}, z =- \frac{x}{8}
Then I put them back into g(x,y,z) = g(x,x/2,x/8)
and get:
g(x,x/2,x/8) = x^2 + \frac{x^2}{4} +\frac{x^2}{64} = 9 \Rightarrow \frac{64x^2 + 16x^2 + x^2}{64} = 9 \Rightarrow \frac{81x^2}{64} = 9 \Rightarrow x = \sqrt{\frac{193}{27}}
but the book says x = 8/3
Can anyone see what mistake did I make? Thank You.
Yeah I do. It's tricky. Let's rewind to... the step before
81x2/64 = 9
So dividing both sides by 81 we get
x2/64 = 1/9
Multiplying both sides by 64 we get
x2 = 64/9
Try solving that one instead
x = 8/3 which agrees with the book. Thank You.
but why couldn't I multiply 9 by 64, and then divide it by 81?
You can, but 9*64/81=192/27=64/9 not 193/27
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
