Determining Tensile Stress on Pressurized Sphere Skin
To determine the tensile stress on the skin of a pressurized sphere, one must decide between using the thin wall approximation or the thick wall formula. The tensile hoop stress can be calculated using the formula s = (p r)/(2 t), where s is the tensile stress, p is the differential pressure, r is the mean wall radius, and t is the membrane thickness. It is recommended to derive the thick member stress formula first, as it can lead to the thin membrane formula. Engineering textbooks on pressure vessels or strength of materials provide foundational formulas for this analysis. Resources like Schaum's Outline of Theory and Problems of Strength of Materials can be beneficial for further study.
linda123
how to determine the tensile stress placed on the skin of a pressurized sphere
Does one wish the thin wall approximation or the formula for the thick wall?
any?
s = (p r)/(2 t), where s is the tensile hoop stress, p is the differential pressure across the membrane (assuming internal pressure is much larger than external pressure), r is the mean wall radius, and t is the membrane thickness.
I would recommend one learn to derive the thick member stress formula from which the thin membrane can then be derived.
Of course, one can look in many engineering books on pressure vessels or strength of materials and find the basic formulae.
Consider purchasing - Schaum's Outline of Theory and Problems of Strength of Materials
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
