Determining the raidus of convergence
  • Thread starter Thread starter bigu01
    Convergence
bigu01
Determine the radius of convergence of the given power serie .
Ʃ(x^(2n))/n!
n goes from 0 to infinity
limit test ratio
I am using the limit test ratio and I've got this : [n! * x^(2n+2)]/[(n+1)! * x^2n], then [n!* x^2n * x^2]/[(n+1) * n! * x^2n] , canceling the common things I am left with lim n-> infinity of x^2/n+1, which is 0, but the radius of convergence is infinity, why is infinity?
Ʃ(x^(2n))/n!
limit test ratio
Because if the ratio test gives you a ratio of r then the corresponding radius of convergence is R=1/r. So as r gets very small the radius of convergence gets very large. If you go all the way to r=0 then R=infinity.
Likes 1 person
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
