Determining β in the L-Shaped Rod Problem
  • Thread starter Thread starter aaronfue
    Rod
The discussion revolves around determining the angle β in the L-shaped rod problem, which is influenced by the angle θ and the geometry of the system. The equation derived for β is β = tan-1((0.24sinθ - EF)/(0.24cosθ + 0.32)), but the value of EF needs clarification. Participants note that FG is not 160 mm, but rather EF is defined as 160 mm, while FG is calculated using AB*sin(θ). The relationship between β and the pulley radius is also highlighted, suggesting that without the radius, β remains indeterminate. The conversation emphasizes the importance of accurately defining all parameters to solve for β effectively.
aaronfue
The position of the L-shaped rod shown is controlled by a cable attached at point B. Determine the angle, β, in terms of θ.
From the FBD attached, I was able to get:
β = tan-1(\frac{0.24sinθ - EF}{0.24cosθ+0.32})
How can I determine what EF is? Is it possible to get an actual number? FG = 0.160
Is the beta angle supposed to be the angle the cable BE makes to the vertical?
Then I think there is something not quite right about your diagram ...
F is vertically above the pivot of the beam and level with the top of the pulley?
It is 160mm horizontally from F to the center of the pulley.
It looks like you'll need the diameter of the pulley.
aaronfue said:
FG = 0.160.
aaronfue: FG is not 160 mm. FG is simply AB*sin(theta), whereas EF = 160 mm.
Here are my current thoughts. Theta can be any value; it is given. Given theta, then I think beta can be any value, depending on the pulley radius. You are given the pulley axle horizontal location, which is EF = 160 mm.
But are you given the pulley radius? If not, I am currently thinking beta will also be a function of pulley radius, r.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
