Find the Diameter of an Iron Disk for Kinetic Energy Storage of 14.6
  • Thread starter Thread starter chrismcr
    Diameter Disk
To determine the diameter of an iron disk for kinetic energy storage of 14.6 MJ at an angular velocity of 91 RPM, the moment of inertia formula I = 0.5mr^2 is essential. The mass of the disk can be expressed using its density (7800 kg/m³) and volume, which is calculated from the disk's thickness (12.4 cm) and radius. The rotational energy equation focuses solely on the disk's rotational motion, allowing for the conversion of RPM to angular velocity (ω). By substituting the mass and volume into the energy equation and solving for the radius, the diameter can be derived. This approach provides a clear method to find the required dimensions for effective kinetic energy storage.
chrismcr
Diameter of disk?
Question: Consider a flywheel made of iron, with a density of 7800 , in the shape of a uniform disk with a thickness of 12.4 . What would the diameter of such a disk need to be if it is to store an amount of kinetic energy of 14.6 when spinning at an angular velocity of 91.0 about an axis perpendicular to the disk at its center?
I know that I=.5mr^2 for the disk, I just don't know how to apply that towards getting a solution for work?
I have pondered this question for some time now, and I know I am just missing one piece, i just don't know what it is. Any help would be greatly appreciated. Thanks
Surely you were not given a problem with all those quantities stated with no units. State the units that go with those numbers. What is the energy of a rotating rigid object?
im sorry..here are the units.
7800kg/m^3
14.6MJ
12.4cm
91RPM
The energy of a rotating object would have to be..
=.5mv^2+.5Iw^2
7800kg/m^3
14.6MJ
12.4cm
91RPM
=.5mv^2+.5Iw^2
For a flywheel, only the rotational energy is of interest. The first term is for translational motion of the CM of the disk, and either there is no such motion or you don't care about it because it is not part of the "stored energy". You know how to find the I of the disk and you can convert the RPM to ω. You can write the mass of the disk in terms of its density and volume, and you can write the volume in terms of the thickness and radius of the disk Put all that into the energy equation with the energy given and solve for R, then find the diameter.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
