Calculating Dielectric Constant: Normalize Capacitance to Thickness & Area
The dielectric constant, or relative permittivity, is crucial for characterizing capacitors and is calculated from measured capacitance normalized to thickness and area. Permittivity measures how an electric field interacts with a dielectric medium, indicating the material's ability to polarize and reduce the internal electric field. It is essential to note that dielectric constant values can vary with frequency and that measurement techniques may introduce errors. The discussion emphasizes the importance of understanding these nuances for accurate dielectric constant measurement. Overall, precise calculation and measurement of dielectric properties are vital for applications in electromagnetism and capacitor design.
CNC
This may seem like a dumb question, but is a dielectric constant calculated from a measured capacitance normalized to thickness and electrode area, I’m having a brain fart.
I'm in a bit of a hurry right now but here are some links.
The dielectric constant k is the relative permittivity of a dielectric material. It is an important parameter in characterizing capacitors. It is unfortunate that the same symbol k is often used for Coulomb's constant, so one must be careful of this possible confusion. It is more typical of physics texts to use the form 1/4πε0 for Coulomb's constant.
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/diel.html"
In electromagnetism, permittivity is the measure of the resistance that is encountered when forming an electric field in a medium. In other words, permittivity is a measure of how an electric field affects, and is affected by, a dielectric medium. Permittivity is determined by the ability of a material to polarize in response to the field, and thereby reduce the total electric field inside the material. Thus, permittivity relates to a material's ability to transmit (or "permit") an electric field.
The permittivity of a medium describes how much electric field (more correctly, flux) is 'generated' per unit charge. Less electric flux exists in a medium with a high permittivity (per unit charge) due to polarization effects.
http://en.wikipedia.org/wiki/Permittivity"
Welcome to PF!
Hi CNC! Welcome to PF! :smile:
From http://www.microwaves101.com/encyclopedia/Measure_dielectric.cfm" …
There are many ways to measure dielectric constant of a material or effective dielectric constant of a media. You can actually make a career out of this measurement, once you know all the nuances and practice a bit. …
Before we attempt describe any methods in various amounts of detail, let's first point out that 1. dielectric constant can vary with frequency (but usually not a lot) and 2. the measurement techniques can be fraught with errors, which we'll try to explain.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
