Difference between products and reactants? Equilibrium
The discussion focuses on calculating the equilibrium constant (Keq) for the reaction C + D <--> A + B, given specific concentrations at equilibrium. Two different interpretations of reactants and products lead to conflicting values for Keq, 1.3 and 0.7638. Clarification is provided that the reaction direction is predetermined and should be followed consistently. Emphasis is placed on understanding the definition of the equilibrium constant to avoid confusion in calculations. Properly identifying reactants and products is crucial for accurate results in equilibrium chemistry.
Ned Taylor
Given the reaction, at equilibrium, it was found that [C] = 0.20 mol/L, [D] = 0.55 mol/L, [A] = 0.30 mol/L and [ B] = 0.48 mol/L. Calculate the value of Keq.
Reaction: C + D <--> A + B
K=products/reactants
[/B]
If we assume that C and D are the reactants then the value of Keq would be:
K=A+B/C+D since K= products/reactants
But if we assume that A+B are the reactants than Keq would be;
K=C+D/A+B
Since these give two difference answers( K=1.3 for the first method, and K=.7638) how does one tell what are the products and reactants. Thanks to anyone who can help me with this!
Ned
You are given reaction and it is clear which way it is intended to be treated.
You are right it is not always obvious, but writing down the equation you are following will always make the situation unambiguous.
Commonly said there are no stupid questions. But if there were any this would be it! :oldbiggrin:
You need to look up the definition of an equilibrium constant. And even without thermodynamics you can understand enough of its rationale and then you would not have written K=C+D/A+B
