Different units in Bernoulli's equation's terms?
The discussion focuses on the unit consistency in Bernoulli's equation, specifically addressing the mismatch between pressure and kinetic energy terms. Initially, there was confusion regarding the units of pressure (force per unit area) and the kinetic energy term, which appeared to differ. After clarification, it was established that in the SI system, pressure is expressed in units of slug/(ft sec^2), aligning with the kinetic energy term's units of slug/(ft sec^2) when properly calculated. This resolution underscores the importance of using correct units in fluid dynamics equations. The conversation highlights the necessity of understanding fundamental physics concepts to avoid unit discrepancies.
sinueus
When I check units in the terms in Bernoulli's equation, they do not match:
Given:
p1 + 1/2 (row) v1^2 = p2 + 1/2 (row) v2^2
On the left hand side of the equation, the first term, pressure must have units of force/unit area; say lb/ft^2. The units in the second term are the product of
row, the density in, say, lb/ft^3
v1^2, the square of speed, say, ft^2/sec^2,
or [lb/ft^3][ft^2/sec^2] = [ lb/(ft sec^2) ] and this is different from the [lb/ft^2] of the first term. Why?
Thanks
A lb isn't a unit of force, it's a units of mass.
I thought so!
Thanks,
I haven't done physics in a log time and I am rusty on the basics. I thoght I had the problem that you mention but was not sure. I'll try again using proper force units and I'll come back.
I am back!
After reviewing my units, I found that in the SI system, the unit of force is the pound (lb), the unit of mass is the slug and that of acceleration is ft/s^2. I remember that 1lb = 1 slug ft/sec^2. Armed with this knowledge, I atacked the problem as follows:
pressure (p) has units of lb/ft^2 = (slug ft)/(sec^2 ft^2) =
slug/(ft sec^2)
velocity has units of ft/sec
row, the density has units of slug/ft^3
Then, the second term in the equation must have units of:
(row)v^2 = [slug/ft^3][ft^2/sec^2] = slug/(ft sec^2)] which matches the pressure units of the first term.
Thanks for the reply. It motivated me to arrive at the right answer.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
