Differentiability and extreme points question
16 replies · 3K views
nhrock3
2.b)
f is continues in [0,1] and differentiable in (0,1)
f(0)=0 and for [tex]x\in(0,1)[/tex] |f'(x)|<=|f(x)| and 0<a<1
prove:
(i)the set {|f(x)| : 0<=x<=a} has maximum
(ii)for every x\in(0,a] this innequality holds [tex]\frac{f(x)}{x}\leq max{|f(x)|:0<=x<=a}[/tex]
(iii)f(x)=0 for [tex]x\in[0,a][/tex]
(iii)f(x)=0 for [tex]x\in[0,1][/tex]
in each of the following subquestion we can use the previosly proves subquestion.
So what did you try?? If you tell us what you tried, then we'll know where to help?
i don't want solution only starting guidence.
for 1 i know the a continues function has a maximum
If you want guidance, then you'll have to show us what you've tried. You won't get a solution here...
there is a difference between solution
and starting guidence
For 1, you indeed use that a continuous function has a maximum. What continuous function do they think they're using here??
i only know about the function what was given
What function do you need to show continuity of??
Yes, that is what we are given.
But we need to prove in (1) that
[tex]\{|f(x)|~\vert~x\in [0,a]\}[/tex]
has a maximum. To show this, we must use that every continuous function on a closed interval has a maximum.
So, what will we take as our continuous function?
we can't take a spesific function
its a proof for all function
a proof for a spesific is not sufficient
You don't understand what micromass is trying to imply. He's not suggesting taking a specific function like f(x) = sinx. He means you need to choose the correct function in your proof, which has to do with f(x) (hint hint), in order to prove that {|f(x)| | 0<= x <= a} has a maximum.
The answer is pretty clear - you just need to formulate a short proof.
Get it?
ahh now i get it
we need to formulate some other functionand using it we prove about
our abstract f(x)
maybe g(X)=|f(x)|
nhrock3 said:
ahh now i get it
our abstract f(x)
maybe g(X)=|f(x)|
Yes, so prove that |f(x)| is continuous if f is.
ionly know one way
and it showing that [tex]lim_{x->x0}f(x)=f(x0)[/tex]
but its not possible
because we don't have an actual function
Can you show |x| to be continuous??
Using that, you can show |f(x)| to be continuous as composition of f(x) and |x|.
nhrock3 said:
ionly know one way
You don't need to show that, it's a given.
Like said above me, asking if the set {|f(x)| | a<=x<=b} has a maximum is just like asking "does the function |f(x)| (notice the absolute value!) get a maximum in the segment [a,b]?". You know there would be an easy answer if you'd say "|f(x)| is continuous on this closed segment and therefore gets a maximum". Therefore, you need to show that |f(x)| is a continuous.
