Differentiability of Functions with Two Real Variables
freya81
Am mainly stuck on parts c) and d) but thought i'd put in the other questions as an aid
2. a) Define what it means to describe a function f of two real variables as differentiable at (a, b)? Define (as limits) the partial derivatives df/dx and df/dy at
(a, b) and prove that if f is differentiable at (a, b) then both these partial derivatives exist.
b) Prove from the definition in a) that the function f defined by f(x,y) =xy(x+y) is differentiable at every point of it’s domain
c) If g(x, y) = xy prove that g is not differentiable at (0, b) for any non- zero value of b
d) Prove that the function g of part c) is differentiable at all points (a,b) for which a is not zero and at the origin (0,0)
it this correct
2. a) f is differentiable at (a,b) iff there exists a linear mapping L such that lim((f(a+h,b+k)-f(a,b)-L(h,k))/|(h,k)|,(h,k)->(0,0))=0. ∂f/∂x(a,b)=lim((f(a+h,b)-f(a,b))/h,h->0), and ∂f/∂y(a,b)=lim((f(a,b+k)-f(a,b))/k,k->0).
does L=grad f; that is, L(h,k)=(∂f/∂x,∂f/∂y).(h,k)=h*∂f/∂x+k*∂f/∂y.
what do i do next?
L is the derivative of f in the direction of the vector <h,k> (i.e. from (a,b) to (a+h,b+k). In a given coordinate system, L is the gradient of f, evaluated at (a,b), dot the vector <h,k>. Note, however, that L, as a linear mapping, exists without a coordinate system. The partial derivatives, of course, depend upon the coordinate system. It is also true, by the way, that a function can have partial derivatives at a point and not be differentiable there.
For b, c, and d, about all I can say is "do it"! You can find the partial derivatives of each so you know what L is for each one. Put the functions and L into the formula in a and do the algebra.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
