Differentiable / continuous functions
jem05
give an example of a function f: R --> R that is differentiable n times at 0, and discontinous everywhere else.
i got one, and i proved everything, i just want to make sure what i did is correct:
f:x n+1 when x is rational
0 when x is irrational
by the way, does the example hold if i invert them, that is 0 if rational and xn+1 if irrational?
(nothing changes right?)
thank you
oh, and x^n does not work, instead of x^n+1, right?
f:x n when x is rational
btw, does the example hold if i invert them, that is 0 if rational and xn if irrational? (nothing changes right?)
thank you
Your function is differentiable (and hence continuous) everywhere on R, except at a finite number of points. Indeed, your function is differentiable on at least \mathbb{R}\setminus\mathbb{Q}.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
