Differential change of variables
sjw11
I am working on an exam question, I have the solution but i can't figure out a step in between,
I need to show that ∂P/∂r = (1/r)∂ψ/∂r - ψ/r^2
I am wondering where the - ψ/r^2 comes from. I.e. which rule is this, and sencondly how does this apply to higher order differentials.
Thanks in advance for all your help
Stuart
Stuart
Hello Stuart. Welcome to PF !
Without knowing how P, ψ, and r are related, it will be hard to answer your question.
Is that P supposed to be ρ ?
Sammy,
Apologies I forgot to put that in
ψ=rP
p=P not ρ
cheers
Then P = \frac{ψ}{r}
\frac{∂P}{∂r} = \frac{∂}{∂r}(ψ\cdot\frac{1}{r}) = \frac{1}{r}\cdot\frac{∂ψ}{∂r} + ψ\cdot\frac{∂}{∂r}(\frac{1}{r})
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
