Differential Eq: Inverse Laplace Transforms
Gogeta007
I have a couple of problems that I am stuck on. The following:
y'' - 6y' + 9y = t
y(0) = 0
y'(0) = 1
and
y'' - 6y' + 13y = 0
y(0) = 0
y'(0) = -3
y'' = s2Y(s) - sf(0) - f'(0)
y' = sY(s) - f(0)
y = Y(s)
for the first one:
once I substitute into the original equation, I can move things around and I came out with the following:
Y(s){s2-6s+9} = (1 +s2)/s2
So I get Y(s) = (1+s2)/s2(s-3)2
IIRC for partial fractions it should be the following: A/(s-3) + B/(s-3)2 + (Cs+D)/s2
I don't know if this is where i messed up but I got:
A=-2/27
B=-1/9
C=2/27
D=1/9
as a final result I get:
-2/27e^3t - 1/92e^3t and the other part (Cs + D)/s^2 . . .I can't find any way to transform that
the back of the book says:
1/9t + 2/27 - 2/27e^3t + 10/9te^3t
The second one:
Starting by substitution, plugging in the values and solving for Y(s)
Y(s) = -3/(s2-6s + 13)
and well. . I am lost from this point onwards. . .I don't remember how to do partial fractions if you can't factorize that denominator. And the quadratic formula (A=1 B = 6 C=13) gives imaginary numbers
Thank you!
-2/27e^3t - 1/92e^3t and the other part (Cs + D)/s^2 . . .I can't find any way to transform that.
You just have to separate it into individual terms.
\frac{Cs+D}{s^2} = \frac{C}{s} + \frac{D}{s^2}
Also, according to Mathematica, you should have B=10/9. The other coefficients you found are correct.
Gogeta007 said:
The second one:
and well. . I'm lost from this point onwards. . .I don't remember how to do partial fractions if you can't factorize that denominator. And the quadratic formula (A=1 B = 6 C=13) gives imaginary numbers.
Complete the square in the bottom so you get something that looks like
Y(s) = -\frac{3}{(s-a)^2+b^2}
You should be able to find the inverse of that using the tables and the properties of Laplace transforms.
wow. . .I can't believe I missed that. . .how does really old math comes back and haunt you huh?. . .thanks a lot
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
