Differential Equation - Determining frequency of beats/rapid oscillations
cse63146
y'' + 6y = 2cos3t
a)Determine frequency of the beats
b)Determine frequency of the rapid oscillations
c)Use the information from parts a) and b) to give a rough sketch of a typical solution
Not sure how to do the first 2 parts. I know the natural period is \frac{2 \pi}{B} and natural frequency is \frac{B}{2 \pi}
The characteristic equation of the homogeneous equation is r2 + 6 = 0, so its solutions are r = +/- i\sqrt{6}. This means that
y_h = Ae^{i\sqrt{6}t} + Be^{-i\sqrt{6}t}
It's more convenient to write a different linear combination of these to get
y_h = c_1cos(\sqrt{6}t) + c_2sin(\sqrt{6}t)
For the nonhomogeneous equation, look for a solution yp = Acos(3t) + Bsin(3t).
The general solution will be yh + yp.
For a, you'll have to figure out how the functions in the homogeneous solution interact with what I'm pretty sure will be the one particular solution function, and how often the waves of the two periodic parts reinforce each other (the beats).
For b, you need to find the rapid oscillation frequency. You have in essence a long wave (low frequency) imposed on a short wave (high frequency).
Hope that helps. It's getting late where I am, so I'm going to turn in.
cse63146 said:
y'' + 6y = 2cos3t
Since there is no "B" in the statement of your problem, that makes no sense! Mark44 has already pointed out that the general solution to the associated homogeneous equation is A cos(\sqrt{6}t)+ B sin(\sqrt{6}t). That tells you that the natural period is 2\pi/\sqrt{6}.
Trig identity: cos(s+ t)= cos(s)cos(t)- sin(s)sin(t) so if you have a formula of the form Acos(2\pi t/\sqrt{6})+ Bcos(3t) you can write that, by careful manipulation of A and B, as cos((2\pi/\sqrt{6}+ 3)t).
It's not a B. It's supposed to be the greek uppercase Beta.
as in - A cos(Bt)+ B sin(Bt). It's how my textbook/prof write it.
In this case B (Beta) = \sqrt{6}
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
