Differential Equation in circuit question
The differential equation governing the circuit's current I(t) is a second-order linear ODE given by L d²I(t)/dt² + R dI(t)/dt + I(t)/C = V(t). For the case where resistance R is neglected and voltage V(t) is constant, the general solution needs to be derived. The user is struggling with the homogeneous equation by setting V(t) to zero and is uncertain about the appropriate ansatz to apply. Initial conditions I(0) = 0 and dI/dt(0) = 0 must also be satisfied in the solution. Assistance is requested to clarify the approach and resolve the difficulties encountered.
scarlets99
In a circuit with capacitance C, inductance L and resistance R the current I(t)
satisfies the differential equation
L d2I(t)/dt2 + R dI(t)/dt + I(t)/C = V(t)
where V (t)
is the voltage supplied.
a) Find the general solution to this differential equation
for the case that the resistance can be neglected, R = 0,
and the voltage is constant, V (t) = V0.
b) Determine the solution of part a) that satisfies the initial conditions I(0) = 0 and dI/dt(0) = 0
As this is a linear second order ODE, with constant coefficients, I have tried calculating the homogeneous equation (place V(t)=0) but cannot seem to get an answer, and I am not sure what ansatz to use.
please help
Show us what you have so far so we can see where you're getting stuck.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
