Differential Equation - Linear Equations (Non - Homogeneous)
cse63146
Find the general solution of \frac{dy}{dt} + 2y = 3t^2 + 2t -1
So just worrying about the right side
y_p = at^2 + bt + c
so \frac{dy_p}{dt} + y_p = 2at + b +at^2 + bt + c = 3t^2+2t - 1
at^2 = 3t^2 \rightarrow a =3
2(3)t + bt = 2t \rightarrow b = -4
(-4) + c = -1 \rightarrow c = 3
Is that part right?
Is that part right?
Substitute it back in and see if it is right? Far better that you learn to check it yourself than for you to ask someone else if it is right.
God, why didn't I think of that? Thank you.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
