Differential equation: word problem
Lo.Lee.Ta.
1. In some chemical reactions, the rate at which the amount of a substance changes with time is proportional to the amount present. For the change of δ-glucono lactone into gluconic acid, for example, dy/dt= -.6y when t is measured in hours.
If there are 90 grams of δ-glucono lactone present when t=0, how many grams will be left after the first hour?
Answer = ___grams
2. Alright, I thought this might be worked like the other differential equation problems.
We are given: dy/dt=-.6y, so I think I have to separate the x's and y's and then integrate.
dy = -.6ydt
∫dy/(-.6y) = ∫dt
∫(1/y)(-1/6)dy = t
ln|y|*-1/6 = t +C
...Is this right so far?
I'm not really sure at all how I would finish the problem, but I will try what I think might be right anyway...
So, would you substitute t=0 and 90 for x?
ln|90|*-1/6 = 0 + C
C = -.75
ln|y| = -6(t + C)
eln|y| = e-6(t+C)
y= e-6(t + C)
So we want to figure out the grams after 60min?
y= e-6( 60 + -.75)
y= 0
...Yeah, I don't know if I'm doing this right at all. :/ But I thought I might try!
Thank you so much for helping! :)
Not that I checked your work thoroughly, but just from skimming:
- 60 min is 1 hour and 0.6 is given for time unit equal 1 hour.
- how did you got 1/6 from 0.6?
Besides, I would integrate \int \frac {dy}{y} = 0.6\int dt, makes the rest of the math less clumsy (in the end you moved 6 back to the RHS).
Edit: typo in the formula corrected.
Answer = ___grams 2. Alright, I thought this might be worked like the other differential equation problems.
dy = -.6ydt
∫dy/(-.6y) = ∫dt
It sould be simpler to leave the "-.6" on the right: dy/y= -.6.
ln(y)= -.6t+ C, y= C'e^{-.6t}.
∫(1/y)(-1/6)dy = t
You have dropped the decimal point: -1/.6, not -1/6.
ln|y|*-1/6 = t +C
ln|90|*-1/6 = 0 + C
C = -.75
ln|y| = -6(t + C)
eln|y| = e-6(t+C)
y= e-6(t + C)
y= e-6( 60 + -.75)
y= 0
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
