Differential equations by series and also by an elementary method
Fachni
Solve the following differential equations by series and also by an elementary method and verify that your solutions agree.
(x^2+2x)y''-2(x+1)y'+2y=0
y=\sum_{n=0}^{\infty} a_nx^n
y'=\sum_{n=1}^{\infty} na_nx^{n-1}
y''=\sum_{n=1}^{\infty} n(n+1)a_{n+1}x^{n-1}
I have got a_1=a_0,\ a_3=0,\ a_4=-\frac{1}{8}a_3=0,\ a_5=-\frac{1}{5}a_4=0. Then, how do we find the recursive relation to find the solution?
Isn't x=0 a singular point? You need to use the Frobenius method to get the series solution.
For the recursion relation, set the coefficient of xn to 0.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
