Differential Equations for Water Flow
4 replies · 6K views
coolxal
Water flows from a conical tank with circular orifice at the rate
[tex]\frac{dx}{dt} = -0.6*\pi*r^2\sqrt{2g}\frac{\sqrt{x}}{A(x)}[/tex]
r is the radius of the orifice, x is the height of the liquid from the vertex of cone, A(x) is area of the cross section of the tank x units above the orifice. Suppose r = 0.1 ft, g = 32.1 ft/s, tank has initial water level of 8ft and initial volume of 512*(pi/3). Computer water level after 10 min with h = 20s.
Modified Euler's Method:
[tex]w_{0} = \alpha[/tex]
[tex]w_{i+1} = w_{i} + \frac{h}{2}[f(t_{i}, w_{i}) + f(t_{i+1}, w_{i} + hf(t_{i}, w_{i}))][/tex]
Is A(8) = (512*(pi/3))/(8/3) = 201.0619?
What do I set for y and t? If the question was f(y, t) = y' = -y + t + 1, 0 <= t <= 1, y(0) = 1, h is the step size, [tex]w_{0} = \alpha = y(0)[/tex] is the initial condition, t is variable between 0 to 1 with step size h, ...
But if I input all those numbers into the equation I get dx/dt = -0.6*pi*0.1^2*sqrt(2*32.1)*sqrt(x)/201.0619 which leaves me with just x. I assume x = t in this case but what is y? How do I get it into the form f(y, t)?
first you need to find A(x) as function of x, not just evaulate it at a point
V = (1/3)*A(x)*x
A(x) = (512*(pi/3))/(x/3)
Is that right?
coolxal said:
V = (1/3)*A(x)*x
Is that right?
not quite, the first line is true, but in the 2nd line you actually subsititute for x = 8ft
so to move forwards you know that at x = 8ft
V = 512*(pi/3)
use that to solve for the radius of the cone base at the point x = 8ft
r(8)
as the triangles are similar you can then use the fact
[tex]\frac{r(x)}{x} = \frac{r(8)}{8}[/tex]
to find r(x) and so A(x)
it probably helpful to know the volume of a cone
[tex]V(x) = \frac{\pi}{3} r^2 x[/tex]
x = height
r = radius of cone base
V = 512*(pi/3)
r(8)
x = height
I used the formula V = (1/3)*B*h where B = A(x) the area and h = x the height so shouldn't A(x) = (512*(pi/3))/(x/3)?
So if [tex]r(x) = \frac{r(8)}{8} x[/tex] and
substitute it for r in [tex]V(x) = \frac{\pi}{3} r^2 x[/tex] it's
[tex]V(x) = \frac{\pi}{3} (\frac{r(8)}{8} x)^2 x[/tex]
[tex]V(8) = \frac{\pi}{3} (\frac{r(8)}{8} 8)^2 8[/tex]
[tex]512\frac{\pi}{3} = \frac{\pi}{3} (\frac{r(8)}{8} 8)^2 8[/tex]
[tex]\frac{512}{8} = (r(8))^2[/tex]
[tex]8 = r(8)[/tex]
What do I do with it?
