Differential equations (swinging door)
Poetria
[/B]
There is a swing door with a damper. The characteristic polynomial (I have done it correctly) is:
0.5*r^2+1.5*r+0.625
General solution for x(0)=x_0 and v(0)=v_0 is (I have found it without a problem):
(1.25*x_0+v_0/2)*e^(-0.5*t)+((v_0+0.5*x_0)/(-2))*e^(-2.5*t)
Now the hell begins:
for x(0)=0.25
What can you say about the initial velocity of the door if, once the door is let go, it swings through the closed position and then swings back from the other side? (a numerical value and an appropriate inequality should be given)
[/B]
Constants c_1 and c_2 given the initial conditions (x_0=0.25).
c_1+c_2=0.25
v_0=(0.25-c_2)*(-0.5)-c_2*(2.5)
The new solution:
(0.25-(v_0+0.125)/(-2))*e^(-0.5*t)+((v_0+0.125)/(-2))*e^(-2.5*t)
Well, now I am at my wits' end. I guess the velocity at the equilibrium position should be less than 0.
Hi, guys, I have solved it at last. No help necessary. Phew.
Likes berkeman
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
