Using Differential Equations to Solve for Velocity of a Free Falling Body
A body falling freely follows the differential equation h'' = -g, leading to the conclusion that its landing velocity is v = -√(2gh(0)). Two methods were discussed: one using integration of acceleration and velocity, and another applying conservation of energy principles. The instructor's expectation is to utilize differential equation techniques, which can be achieved by solving for h(t) and deriving v(t) from it. By substituting the time of fall into the velocity equation, the result confirms the landing velocity as v(t) = -√(2gh(0)). Understanding these methods clarifies the relationship between height, time, and velocity in free fall scenarios.
mekkomhada
1) Show that since a body falling freely obeys the differential equation h&#039;&#039;=-g[/itex], if it falls from an initial height h(0), it lands with a velocity of -\sqrt{2gh(0)}<br /> <br /> This problem is from a differential equations class and I solved it two different ways:<br /> <br /> <u><b>Method 1</b></u>:<br /> \frac {dh} {dt}=v and \frac {dv} {dt}=a which leads to \int{a dh}=\int{v dv} and solving for v gives you v=\sqrt{2gh}<br /> <br /> <u><b>Method 2</b></u>:<br /> Use KE=PE, so \frac{1}{2}mv^2=mgh<br /> and solve for v which gives you v=\sqrt{2gh}.<br /> <br /> Unfortunately I don&#039;t think this is what the instructor is looking for. The wording of the question suggests he wants me to use differential equations techniques. I solved the DE to get h=-\frac{1}{2}gt^2+c_1t+c_2 but I&#039;m not seeing how that will get me to v=-\sqrt{2gh(0)}<br /> <br /> Can anyone help me?
The velocity's equation v(t) is v(t)=v_{0}-gt If u take the initial velocity to be zero and u found the falling time in terms of the height,then it's easy to get
v\left(t_{\mbox{falling}\right)=-\sqrt{2g h(0)}
Daniel.
Actually, your "method 1" is a differential equation method.
However, you can, as you say get h(t)= -\frac{1}{2}gt^2+ c_1t+ c_2 and then v(t)= h&#039;(t)= -gt+ c_1.
Taking t= 0 to be the moment the body is dropped, h(0)= c_2 and v(0)= c_1= 0 so
h(t)= -\frac{1}{2}gt^2+ h(0) and v(t)= -gt.
The body "lands" when h(t)= 0. Solve h(t)= -\frac{1}{2}gt^2+ h(0)= 0, which is thesame as t^2= \frac{2h(0)}{g}, (of course, you only want the positive root) and put into v(t)= -gt to find speed with which it lands.
Thanks for helping me out...I don't know why, but the answer wasn't immediately apparent to me. I need a break :-p
