Differential Geometry, curve length
Stimpon
L[c]:=\int_{a}^{b}(\sum_{i,j=1}^{2}g_{ij}(c(t))c_{i}'(t)c_{j}'(t))^{1/2}dt
So g_{ij}(x,y)=0 for i{\neq}j, c_{1}'(t)=-Rsin(t), c_{2}'(t)=Rcos(t)
so L[c]:=\int_{a}^{b}(\frac{1}{((Rsin(t))^{2}}R^{2}(sin^{2}(t)+cos^{2}(t))^{1/2}dt=\int_{a}^{b}\frac{1}{sin(t)}dt
However the solutions has
L[c]:=\int_{a}^{b}(\frac{1}{((Rcos(t))^{2}}R^{2}(sin^{2}(t)+cos^{2}(t))^{1/2}dt=\int_{a}^{b}\frac{1}{cos(t)}dt
and he then goes on to use the given identity to find an antiderivative for \frac{1}{cost}
but I don't see how he has cost where I have sint.
Is he making a mistake or am I?
I wonder how come the hint is right but the solution in the text isn't.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
