Differential Lengths (Cylinder & Sphere)
Meadman23
This isn't a homework problem, but I was wondering if anyone could explain two things to me.
1. When you have the differential lengths of a cylinder:dlr= dr dl\theta = r d\theta dlz = dz
Why is dl\theta equal to r d\theta and not just d\theta?2. When you have the differential lengths of a sphere:
dlR = dR dl\theta = R d\theta dl\varphi = R sin\theta d\varphi
Why is dl\theta equal to R d\theta and why is \varphi equal to R sin\theta d\varphi?I really want to be able to see rather than memorize what each of these differential lengths are equal to.
As I recall, the rdθ has to do with radians. When you're on a circle, and you move through an angle θ, you have traveled a distance rθ (provided θ is measured in radians!). If you move through an infinitesimal angle dθ you have gone a distance rdθ.
As for spherical, notice that θ is the angle from the z-axis (I think?) then the radius in the X-Y plane is Rsinθ, so by the same radian argument, an infinitesmal movement in the phi direction (angle from the x-axis) should be Rsinθdψ (I can't believe they don't have phi!).
And same goes for Rdθ in the θ direction (angle from the z-axis).
hope this helps!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
