How Does Increasing Engine Power Affect a Funny Car's Track Time?
Increasing engine power in a funny car affects its track time by altering the acceleration dynamics. The discussion highlights that the formulas for power and distance must account for varying acceleration, as they are not constant in this scenario. The correct approach involves using the relationship between force, acceleration, and power to derive the time change due to a differential increase in power. Participants emphasize the need to apply calculus to relate acceleration and velocity accurately over the run. Understanding these dynamics is crucial for determining how changes in engine power impact overall performance.
napaul
A funny car accelerates from rest through a measured track distance in time T with the engine operating at a constant power P. If the track crew can increase the engine power by a differential amount dP, what is the change in the time required for the run? (Use any variable or symbol stated above as necessary.)
I think its:
P = dW/dT
P = Fvcos(Phi) = F dot v
D = 1/2aT^2
Sorry this is my first post, please be lenient on me...
Okay, so far I started with
P = dW/dT = F [dot] V
F = (ma)
V = aT
so P = ma(aT)cos(Phi)
P = [mTa^2] cos(Phi)
P = mT[(2d)/T^2]^2 cos(Phi)
P = mT[(4d^2)/T^4] cos(Phi)
P = [4md^2/T^3] cos(Phi)
dP/dT = [8md/3T^2] [-sin(Phi)]
dT = [[3T^2(dP)/8md] [-sin(Phi)]
I know its wrong, but I need some guidance because I'm really confused...
Welcome to PF, napaul! :smile:
I think its:
P = dW/dT
D = 1/2aT^2
Your formulas for P are correct.
However, I'm afraid your formula for D is wrong.
F = (ma)
V = aT
Similarly your formula for V is wrong.
Your formula for D and V only hold when acceleration a is constant, which in this case it is not.
The proper formulas are:
dv = adt \quad \text{or} \quad v=v_0 + \int_0^t a dt
dx = vdt \quad \text{or} \quad D=\int_0^T v dt
You can get "a" as a function of "v" from F=ma and P=Fv=constant.
From there you should solve dv=adt...
Btw, you can leave Phi out of your equations since a car would always accelerate in the direction of its speed.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
