How do I find the derivative of f(x)=x+9/x without using the power rule?
  • Thread starter Thread starter efekwulsemmay
    Differentiation
efekwulsemmay
This is the larger problem to the small portion that I already posted in the Precalc Hw help forum. I still can't figure out how to get to the answer.
The problem is this:
I am trying to find the derivative of f(x)=x+\frac{9}{x}.
I know via power rule that the answer will be:
\frac{dy}{dx}=1+\frac{9}{x^{2}}
However, I must do it the messy way.
This is what I have got so far:
1.\frac{f(x+h)-f(x)}{h}
2.=\lim_{h\rightarrow0}\frac{\left((x+h)+\frac{9}{x+h}\right)-\left(x+\frac{9}{x}\right)}{h}
3.=\lim_{h\rightarrow0}\frac{x+h+\frac{9}{x+h}-x-\frac{9}{x}}{h}
4.=\lim_{h\rightarrow0}\frac{h}{h}+\frac{\frac{9}{x+h}}{h}-\frac{\frac{9}{x}}{h}
5.=\lim_{h\rightarrow0}1+\left(\frac{9h}{x+h}-\frac{9h}{x}\right)
6.=\lim_{h\rightarrow0}1+\left(\frac{x}{x}\cdot\frac{9h}{x+h}-\frac{9h}{x}\cdot\frac{x+h}{x+h}\right)
7.=\lim_{h\rightarrow0}1+\frac{9hx-9hx-9h^{2}}{x(x+h)}
8.=\lim_{h\rightarrow0}1+\frac{-9h^{2}}{x(x+h)}
I don't know where to go from here or even if here is where I am supposed to be. Help please?
Feldoh said:
Partial fraction decomposition might work.
Partial whos-a-what? :confused:
You were doing fine until step 5. Then you changed (9/(x+h)-9/x)/h into (9h/(x+h)-9h/x). You can't do that. You just moved h into the numerator by 'magic'. Leave it in the denominator! You also don't want to multiply by h/h in the next step. You want to multiply by x/x to get the common denominator.
Ok that's where I went wrong. Thanks for your help. :biggrin: Btw the multiplying h/h was a typo, its supposed to be x/x.
Awesome. So going by what you said Dick, I figured out that I messed up by putting that h in the numerator (slopy fraction solving :) ) I worked it out and got the right answer. Thanks for your help Dick.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
