Differentiation: Product rule and composite rule
imy786
Use differentiation to verify that the following integrals are correct (where a is not = 0 is a constant and c is an arbitrary constant
(a) integrate xsinax dx= ( −x/a ) (cosax) +(1/a2) sinax+c
(b) integrate tanax dx=(−1/a) ln(cosax)+c
Composite rule dy/dx = (dy/du) (du/dx)
Im not getting the right solution after diffrenting.
attached are my solutions
I don't see an attachment. For the first problem, you also need the product rule. For the second one, you need to use the chain rule twice.
(Edited after Mark44's reply below).
What both of you are referring to as the "composition" rule, most books that I've seen call the chain rule.
Hm, for some reason I didn't even realize that I was just repeating what he said in a slightly different way. :rolleyes: Yes, the "chain rule" is what I'd normally call it. I don't think I've seen it called anything else in a book.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
