Difficult Mass Exchanger Question
  • Thread starter Ciocolatta
  • Tags
    Mass
N) using the equation provided above:N = K * A * deltaC(LMTD) = (0.023 m/s)(A)(0) = 0 kg/sFinally, to compare the mass transfer area required with the original mass transfer area from the specification of the design variables, we can use the equation N = K * A * deltaC(LMTD) again, but this time we solve for A:A = N / (K * deltaC(LMTD)) = (0 kg/s) / (0.023 m/s * 0) = undefinedIn summary, to design an evaporator to move 1000 kg/h of water from a milk
Ciocolatta
An evaporator is required to move 1000kgh-1 of water from a milk stream.
Steam is available for heating the evaporator (by condensation) at a pressure of 70.1 kPa absolute and a temperature of 90 decrees celcius.
The vapour, into which the water is evaporated from the milk, is at a pressure of 47.4kPa absolute and a temperature of 80 degrees celcius.
Number of tubes: 50
Tube inside diameter: 50mm
Tube length: 3m
tube thickness: 3mm
do one pass through calculation to
a) estimate an overall mass transfer coefficient for the evaporation
b) estimate the driving force for mass transfer
c) compare the mass transfer area required wit hthe original mass transfer area from the specification of the design variables.
antoine equation:
pressure(Pa) = 133.3 exp (18.3036 - 3816.44/(T(in celcius) + 277.02))
heat of vaporisation for water/steam = 2200 kJ/kg
properties for steam (both condensing and evaporating):
K (W/mK) = 0.023
density (kg/m3) = 0.45
Diff (m2/s) = 1.5 x 10^5
viscosity (kg/ms) = 1 x 10^-5
thermal conductivity of tube material: 45 W/mK
condensation heat transfer coefficient for steam at 90 degrees celcius: 10,000 W/m2K
overall mass transfer coefficient (m/s) from gas phase perspective:
K = 1 / [1/k(gas) + H(gas->liquid)/k(liquid)]
k(gas) = gas film mass transfer coeff
k(liquid) = liquid film mass transfer coeff
H(gas->liquid) = henry's law constant between liquid and gas (dimensionoless)
N = mass transfer rate (kg/s)
A = mas transfer area (m2)
deltaC(LMTD) = log mean concentrarion driving force (kg/m3) = deltaC1-deltaC2/ln(deltaC1/deltaC2))
C1 and C2 are concentration driving forces at one and the other end of the mass exchanger.
this is a design question...so we're allowed to make assumptions where necessary. But the problem is...I'm not sure if I'm allowed to assume some mass transfer coefficients or if I can calculate them with the information above.
I don't really understand how to do this.
im assuming the gas MT coeff = 20, and liquid MT coeff = 200 which fall in the typical ranges
and i think henry's constant for gas --> liquid = gas mole frac/ liquid mole frac
where gas mole frac = absolute pressure of water in steam / absolute pressure of steam = 47.4/70.1
im really stuck... =/
Thank you for your post. I am a scientist and I would be happy to assist you with your questions.
To estimate the overall mass transfer coefficient for the evaporation, we can use the equation provided in the homework, which is K = 1 / [1/k(gas) + H(gas->liquid)/k(liquid)]. As you mentioned, we can assume the gas mass transfer coefficient (k(gas)) to be 20 and the liquid mass transfer coefficient (k(liquid)) to be 200. However, we do not need to assume the Henry's law constant (H(gas->liquid)) as it can be calculated using the information provided.
H(gas->liquid) = gas mole frac/ liquid mole frac = (absolute pressure of water in steam / absolute pressure of steam) = (47.4/70.1) = 0.676
Using this value of H(gas->liquid), we can now calculate the overall mass transfer coefficient (K) as follows:
K = 1 / [1/20 + 0.676/200] = 0.023 m/s
To estimate the driving force for mass transfer, we can use the equation N = K * A * deltaC(LMTD). Here, N is the mass transfer rate, K is the overall mass transfer coefficient calculated above, A is the mass transfer area, and deltaC(LMTD) is the log mean concentration driving force. We can calculate deltaC(LMTD) using the information provided as follows:
deltaC(LMTD) = log mean concentration driving force (kg/m3) = deltaC1-deltaC2/ln(deltaC1/deltaC2))
Since we are given the mass flow rate (1000 kg/h), we can calculate the concentration driving force using the density of water (1000 kg/m3) and the mass flow rate as follows:
deltaC = mass flow rate / density = (1000 kg/h)/(1000 kg/m3) = 1 kg/m3
Therefore, deltaC1 = deltaC2 = 1 kg/m3
Plugging these values into the equation for deltaC(LMTD), we get:
deltaC(LMTD) = ((1-1)/ln(1/1)) = 0
Now, we
1. What is a Difficult Mass Exchanger Question?
A Difficult Mass Exchanger Question is a complex problem that involves the exchange of mass between two or more systems. It often requires advanced knowledge of mass transfer principles and calculations.
2. How do you solve a Difficult Mass Exchanger Question?
Solving a Difficult Mass Exchanger Question requires a systematic approach, including identifying the relevant variables, applying mass balance equations, and using appropriate mass transfer coefficients. It also involves checking for assumptions and using appropriate units and conversions.
3. What are some common challenges when solving Difficult Mass Exchanger Questions?
Some common challenges when solving Difficult Mass Exchanger Questions include dealing with non-ideal conditions, accounting for multiple phases, and handling complex reactions or equilibrium calculations. It may also involve using computer software or experimental data to aid in the solution.
4. How can I improve my understanding of Difficult Mass Exchanger Questions?
To improve your understanding of Difficult Mass Exchanger Questions, it is important to have a strong foundation in mass transfer principles and calculations. Additionally, practicing with various types of problems and seeking guidance from experienced individuals or resources can also help improve understanding.
5. What are some real-world applications of Difficult Mass Exchanger Questions?
Difficult Mass Exchanger Questions have numerous real-world applications, including in chemical and environmental engineering, pharmaceutical and food industries, and in energy production and storage. They are used to optimize processes, design equipment, and solve complex mass transfer problems in various industries.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Thermodynamics
10K
