Diffraction and phase difference
The discussion focuses on understanding the path and phase differences of parallel rays emerging from a single slit, particularly at the first and second minima. Key points include calculating phase differences using the relationship a*sin θ = mλ, where 'a' is the slit width and λ is the wavelength. The method involves determining the distance traveled by rays from different points within the slit, applying the Pythagorean theorem, and converting distance differences into phase differences. The conversation also highlights the importance of recognizing patterns in these calculations to simplify the process. Ultimately, the analysis of single slit diffraction requires a comprehensive approach beyond just identifying nulls.
CINA
Hi,
I'm having some trouble understanding the path difference between two parallel rays leaving a single slit, and was hoping you guys could help me. I'm having a hard time understand what path differences exist for each subsection of a slit and for which minimum. For example:
-What is the phase difference of two rays leaving the top and bottom of a slit ( width 'a' ) at the first minimum.
-What about two rays leaving from the top and a/2 at the first minimum? At the top and a/4?
-What about two rays leaving the top and bottom at the second minimum?
-What about two rays leaving the top and a/2 at the second minimum?
Does this just come from the a*sin θ = mλ?
Science news on Phys.org
You need to know that a wave cycles through 2pi phase each time it propagates a distance equal to its wavelength. So if you know the wavelength, to get the phase at the screen you just need to calculate the distance and divide by the wavelength, and look at the fractional non-integer remainder. Multiply that fractional remainder by 2pi and that's the phase it arrives at the screen with. Do it again for another place in the slit, you get a different answer because the distance is different (you'll need nothing but the Pythagorean theorem). Take the difference between those answers, and you get the phase difference. After you do this a few times, you'll note some patterns that make it easier to extract the general rule there. (Working to lowest order in a/d simplifies these expressions drastically, and is normally done.)
The two slits (Young's) calculation tells you where you will get cancellation between the two elements, treating them as point sources. The textbook treatment for a single slit divides the (vertical) slit into a left half and a right half and works out the resultant for pairs of elemental slits which are separated by half the slit width and adds them up (progressing from simple interference to diffraction, that is). The angles of the nulls from all the pairs will coincide to give you the nulls on the single slit diffraction pattern. However, you need to do more than that to find the actual values away from the nulls.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
