Error Analysis of Op-Amp Output with Tolerances on Inputs and Resistors
The discussion focuses on understanding the significance of tolerance in resistors and its impact on the output of an op-amp circuit. Tolerance indicates the acceptable range of variation in resistor values, which affects the accuracy of the circuit's output voltage. The output voltage of the op-amp is influenced by the tolerances of both the input voltages and the resistors, leading to potential errors in the Digital-to-Analog Converter (DAC) output. Participants express confusion about how to calculate the output voltage's tolerance given the independent variations in the resistors and input voltages. The conversation emphasizes the importance of error propagation in determining the overall accuracy of the op-amp output.
ranju
The input bits 0 and 1 are represented by 0 volts and 5 volts respectively. The OP-AMP is ideal, but all the resistances and the 5 volts inputs have a tolerance o f ± 10%. The specification (rounded to the nearest multiple of 5%) for the tolerance of the DAC is??
In this question all I want to know is what is the physical significance of the term tolerance as given for the resistor , what's the purpose?? And we have to find tolerance of dac , what does this mean??
In the solution , they found out the output voltage of op-amp and put the values of the individual tolerances..how they got to know that we have to find output voltage's tolerance from the given problem??
Voutput = -Vr [Rf/R] where Vr is the reference voltage [/B]
[/B]
No resistors are exact. Say ( in this example ) that you have bought a resistor marked with the colors:
brown - black - orange - silver :
It means that this resistor is specified: 10 * 103Ω ± 10%
The shown DAC doesn't care about the voltages connected to the inputs, but about the currents flowing in the resistors: I = V / R. So if a connected voltage to some input is 10% too high, and that the resistor for the same input is 10% too small, what will the resulting output from the DAC be, as compared to the ideal output, due to this input?
Confusing post.
Only thing I can figure out is you want to know the error band in the op amp's output given 10% tolerance on the 5V inputs and the resistors?
In which case, how do errors propagate when the output is a product of three parameters (2 resistors & 1 input voltage), all assumed independent of each other and normally distributed?
